Axles on G. question
SC Dan K. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SC Dan K. Quote  Post ReplyReply Direct Link To This Post Topic: Axles on G. question
    Posted: 14 Oct 2011 at 8:11pm
How do you check the oil in G axle's? I looked can't see any place to check.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2011 at 8:19pm
Axles in a G don't run in oil. The outer bearing is sealed, the inner area is supported at the ring gear by the axle gears. Any oil or grease out in the brakes or tube is due to bad seals.
The oil level for the transmission and rear end is checked by the large plug right behind the pivot of the clutch pedal. You should the the words "oil level" cast into the housing there.
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
