Auction Results
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Topic: Auction Results
    Posted: 21 Aug 2010 at 2:50pm
Went to the Powell Farms Auction in Campbellsburg, KY this morning to see what they had.  There were 2 D-19 gassers there, a B, a G, and a WD that wasn't running.  The first D19 gasser was in its work clothes.  It was all there, had an aftermarket 3pt on it, but looked like it had a lot of hours on it.  It went for $1875.  I went with it to $1850, but another person jumped in at the last minute, and I didn't want to spend more than $1800 really, but thought the $1850 had it won, so I quit on it after the new person jumped in.  The second one was a good looker at first, but then after looking at it, it seemed to just have a paint job overhaul.  I think it was someone's puller they threw together.  It had a recent tune up, fluids looked good, but had an aftermarket hydraulic valve on the back, then I noticed the factory air intake tube was missing that came to the carb so I peeked up under the hood and saw someone had made new hose out of PVC pipe and radiator hose, completely eleminating an air filter.  So after I saw that, I called my limit at the same as the other tractor.  It was said to not jump out of gear, fired right off, but had a quick miss when throttled up.  It went for $2000 (I didn't even bid on it).  There was a B that had a quick paint job, JB welded steering arm, and was pretty rough looking under the paint and new seat that went for $500.  The WD went for about the same I believe, I didn't see it go.  The G I believe went in the $2500 range according to a guy I know that was there.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Texas B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Texas B Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2010 at 5:16pm
Well JB Weld on the B Steering arm must be common - mine has the same - ordered another one.  I just JB with a lot, not my life or kids.
Texas B 39
