Auction Miss!
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Topic: Auction Miss!
    Posted: 16 Mar 2017 at 8:15pm
I went to auction last Saturday to check on some items,---ac-b ---$450. ac-c $500.--not running and kinda stuck, 1 back and1 front tire on each one flat, both were dragged out of a shed that was being torn down.----I just missed out on bidding on them, as I was over at the other auction line buying chainsaws (3 of them)!---Hate when they run more than 1 line!---miss a LOT of stuff that way!
Stuff was selling high too.----I had the top bid on a Cat. D-7-17a,---- but the seller wouldn't take that low of a bid for it so they passed it up!!
Missed a auction today because the ferd diesel thermostat stuck just up the road, forcing us to turn back! thanks; ac fleet
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2017 at 9:02pm
Next time that happens peck on the thermostat housing and usually they'll open up. Then put a can of water pump lubricant in the rad. and that most likely will fix it.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2017 at 6:40am
I missed the Storey Tractor auction because of scheduling conflict. I'm still kicking myself for that one....  There were WD and D parts tractors galore. And I need the parts. The stuff was cheap I heard. Whole tractors less than $100
Edited by corbinstein - 17 Mar 2017 at 6:41am
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2017 at 7:24am
If you want a 2nd chance I'll sell you a C you can drive on the trailer for $450.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2017 at 10:09pm
I am limited on travel,---right now I can't leave the driveway!! Explorer gotta have gas tank and fuel pump replaced, so it not running and today I did get the junk diesel drained so I can attempt to break off 3 thermo. cover micro screws!---wot a crock!---should have 3/8" hold down bolts instead of what stupid Navistar used!---(they never could build a decent v-8 diesel motor)! The pickup still don't start when warm and I think it has a small leak in the bottom of the rad. so we are kinda stranded, again!!! lol!!!---To add to it,-- I am missing 1 little chainsaw!----It wasn't running, so it had to be carried off by someone!---P#&&%& me off!---- I don't have THAT many saws to start with!  thanks; ac fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2017 at 12:12pm
Here I thought you found a new gal to follow around at auctions........
You get it to WI and I'll give you that! Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2017 at 1:27pm
Seems tractor prices are down somewhat.  I passed up a JD 450 crawler with front blade yesterday because I really don't need it and I don't have anything to haul it on. It ran good and had good hydraulics, not sure about the undercarriage, went for $6750. I don't like those two line auctions either, missed bidding on some things because I was watching something in the other line.
This page was generated in 0.180 seconds.
