ARGO 6x6 ...yeesh.. |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25208 |
Topic: ARGO 6x6 ...yeesh..Posted: 28 Jan 2023 at 9:40am |
so neighbor drives his 2nd hand, 59 hour, 'hard starting' ARGO over for me to look at..... hmm, 23HP B&S Vanguard engine. if you bypass the starter solenoid (screwdriver), nice... so probably needs a new solenoid... OK, WHERE's the 'engineer' who decided that using a gear clamp to secure the solenoid onto the starter was a 'good' idea ?? I want him here, NOW, to replace the solenoid !!! There is NO way a normal human can do it.heck I can't even 'feel-find' the clamp screw. OK, no big deal,if you're stuck in the bush, there's always the recoil start.... NOT. Same 'engineer' expect you to remove the 'firewall' ,fish your hand through a maze of SHARP mechanically things then pull the cord ??? I'd like a demonstration please ! At the end of the 3 hours , I had 2 suggestions(3 really,shhhh ) 1..keep long screwdriver IN the ARGO, so jump start when needed...... 2) spend 2 dayze this summer and rotate the recoil from 9oclock to 2oclock. They may be 'cute' and 'useful' but NOT easy to work on.
Kansas99
Joined: 26 Feb 2015 Location: W Kansas Points: 4868 |
Posted: 29 Jan 2023 at 11:09am |
Should have got a terra tiger
jaybmiller
Posted: 30 Jan 2023 at 9:02am |
heck, I'm just HAPPY that I will NOT be working on it !!!
