Arena tractor pull 5-1-10 Info |
Post Reply |
AndyinWI
Orange Level Joined: 22 Sep 2009 Location: Blue Mounds Points: 416 |
Posted: 11 Apr 2010 at 9:57pm |
1st Annual Arena, WI Tractor Pull Saturday May 1st, 2010
Arena Park in the middle of town
Weigh-in start @ 9am Pulling @10am sharp
$20.00 Entry Fee per Hook.
Antique/Antique Open 1959 and Older
4000 lb. Antique
4500 lb. Antique 4500 lb. Antique Open
5000 lb. Antique 5000 lb. Antique Open
5500 lb. Antique 5500 lb. Antique Open
Farm/Open Farm
6000 lb. Farm 6000 lb. Open Farm
6500 lb. Farm 6500 lb. Open Farm
7500 lb. Farm/N.A.
8500 lb. Farm/N.A. -4cyl factory turbo
9500 lb. Farm/N.A. -4cyl factory turbo
10,500 lb. Farm
12,500 lb. Farm
14,500 lb. Farm
16,500 lb. Farm
Improved Farm (aka 2 Hot 2 Farm)
10,500 11,500 12,500
Contacts:
Andy Gray 608-235-3015 Antiques & General
Matt Ruskosky 608-577-9678 Farm & General
Vern Meinholz 608-220-6695 Improved Farm(aka 2 Hot) & General
Regular Antique
Classes will have a 15.5x38 tire limit. Only exception will be 16.9x28 which are allowed.
1st gear only with no 2 speed shift.
18” drawbar height.
10% over stock RPM. RPM can be checked at any time
Antique Open
Classes will have an 18.4x38 tire limit.
3000 RPM limit unless ALL safety equipment in place. (steel flywheel, blanket, kill switch, side shields, and wheelie bars)
18” drawbar height.
Farm
Classes thru 9500 lb. will have 18.4x38 tire limit.
10,500 lb. and up will be 20.8x38 (20.8x42 will be allowed)
3000 RPM limit.
20” drawbar height.
Open Farm
20” drawbar height.
Classes will have 20.8x42 tire limit.
3000 RPM limit
20” drawbar height.
General Rules
*Official’s rulings are final.
*RPM can be checked at ANY time.
*2 hooks per driver allowed.
*No alcohol consumption until you are done pulling.
*All weights must be secured to tractor.
*Any tractor that loses ANYTHING onto track while competing is disqualified.
*No passengers allowed on tractors at ANY time. This includes pit and staging area.
*Officials reserve right to move tractors to a higher class if deemed overly modified for Antique or Farm classes.
*Pullers minimum age requirement is 16 years old unless completed tractor safety course certificate is provided.
Allis Fields
Orange Level Joined: 17 Sep 2009 Location: Reedsburg,Wisc. Points: 332 |
bump
GlenninPA
Orange Level Joined: 11 Sep 2009 Location: Ashley, PA Points: 5054 |
why don't you go ahead and post it over on the calendar in the Events page?
Allis Fields
Bump
Allis Fields
Bump
Post Reply | |
