Are pistons & liners matched in a new kit?
J&J View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote J&J Quote  Post ReplyReply Direct Link To This Post Topic: Are pistons & liners matched in a new kit?
    Posted: 31 Jan 2026 at 12:07pm
Just received a new overhaul kit from A&I for a CA. Are the pistons and liners matched to each other? They came boxed with the piston inside the liner, but there are no markings or tags that specifically mate the two together?
RedHeeler79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2026 at 12:33pm
No, they’re generally not matched. Just mass produced and packaged as a set. Would undoubtedly cost considerably more if they were factory matched. As long as the manufacturer maintains tight quality control / tolerances, all should be good. You could take the time to measure piston to wall clearance and ring gap (recommended), and put together the closest matches you can achieve with what you have…. I bet most people don’t though. And if they’re on the loose end of spec, there’s not much you can do anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2026 at 12:36pm
Unfortunately, most engine parts that i see currently being produced are made overseas (chineseum), and in my opinion, not the top quality that you used to be able to get with the old USA made brands of years ago. I always try hard to find NOS stuff, but not always possible. Sad, but unfortunately what we’re faced with in today’s world.
Edited by RedHeeler79 - 31 Jan 2026 at 12:37pm
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2026 at 12:10pm
Nothing has been matched like that since Rolls-Royce was hand assembling Merlin V12's in 1940. Interchangable parts is the industry standard for mass production. All parts are made to specific tolerances so they may be interchanged in any different engine, within that model. Don't expect any piston/sleeve these days to be size matched to one another.
www.awtractor.com
A&W TRACTOR 920-598-1287
