are D17 and WD45 distributors the same, interchan?
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Topic: are D17 and WD45 distributors the same, interchan?
    Posted: 15 Mar 2026 at 7:25pm
just need to know the answer to that question. thanks michael
The 15th Annual Exclusive AC Swap Meet will be held in Boonville, MO, March 6-7, 2026. See the club website for details: http://www.moacclub.com/
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2026 at 8:25am
Had a Series 1 D 17 with power steering which of course works thru the distributor.  Sold the distributor/power steering off the D 17.  Installed a WD 45 distributor so I say they are basically the same.
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2026 at 8:46am
I would bet they are but don't know. Sounds like Den maybe switched the drive housing and all and I can see that working. Sounds like you are talking just the distributor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2026 at 8:53am
I didn't get a chance to look this morning. Digging out from the snow was priority. The distributers will interchange, but I'm real sure the timing advance mechanisms are slightly different. The WD45 engine probably reaches full timing advance by 1400 RPM, which is rated speed. The D-17 engine reaches full advance by 1650 or 1700 RPM because that's where rated speed is on that engine. So, if you used a D-17 dist on a WD45 engine, full advance wouldn't occur quite soon enough, as high idle is 1700 RPM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2026 at 9:14am
Interchangeability and sameness are two different things. I'm sure Doc nailed it
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2026 at 12:27pm
I would want to know the complete curve characteristics:
When does it begin advancing?
When is it fully advanced?
Total amount it advances; ie 20, 25, 30... etc. degrees.
Is the advance linear?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2026 at 12:34pm
WD-45's should have always been a total of 30 degrees advance from dead stopped to full throttle, hitting that full 30 degrees of advance by rated speed of 1400 RPM.  Early D-17's would also have had a 30 degree advance, only peaking at 1650-1700 RPM.  By the series 2 models, they had the engines timed at 25 degrees BTDC, so I assume they had to change the advance to those specs, instead of 30 degrees like the early D-17's..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2026 at 5:43pm
thanks so much.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:55am
First D-17 I had had a different style cap, don't remember if the rotor was different too or not. Was held on with screws, not clips. It would probably interchange?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:57am
One-Seventy's/170's had the 2-screw Delco cap. All D-17's had the snap-clips. The newer Delco would have had the same timing advance performance.
Edited by DrAllis - Yesterday at 8:22am
