anyone installe a calc-an-acre on 4wd? |
gleaner000 ![]() Bronze Level ![]() ![]() Joined: 05 Jan 2012 Location: grand ledge Points: 13 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Apr 2012 at 5:32pm |
has anyone installed a calc-an-acre on a 4wd? I bought one from shoup for our old horse with no speed sensor. how many magnets did u use if so?
thanx
D-17_Dave ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mocksville NC Points: 990 |
I installed dozens of these years back on the Tobacco harvesters we made. I think we used 6 magnets on a torque hub. 5 or 6 will work as you put the calc into a program mode and drive the distance after installed onto machine over a measured distance. This will calibrate the unit to the actual speed.
Yea, I can fix that.....
John (C-IL) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Illinois Points: 1654 |
The more you use the more acurate it will be. I put one on my Kawasaki Mule and found that 2 magnets were not enough to measure accurately. I went to 8 and that solved the problem, I'm now accurate to .2 foot. If you can put them on the hub at least 4 will give you a decent reading.
Mike Kroupa ![]() Silver Level ![]() Joined: 02 Oct 2009 Location: pierce, ne Points: 337 |
I have one on my Steiger pta280, glued the two magnets to the front driveshaft., Mike
mike,
does the driveshaft method work well?
