Anyone balancing engines.... |
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3539 |
Topic: Anyone balancing engines....Posted: 13 Dec 2021 at 11:23pm |
at overhaul?
8070 / 7080 higher Rpm engines? We have no idea if it pays - but the last two 426 engines we had balanced came back with an unbelievable amount of drilling and grinding, especially on pistons and rods. Speed shop said they had never worked on components that much out of balance.... |
ryan(IN)
Joined: 11 Sep 2009 Location: Bluffton,IN Points: 789 |
Posted: 14 Dec 2021 at 5:35am |
I believe they balanced our 7060 when we overhauled it. It’s the smoothest running 426 I’ve been around.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62 |
Posted: 14 Dec 2021 at 5:51am |
Back in 1978 when I built a puller, the machine shop said the rods were the worst part of the imbalance on a 7030 engine.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5163 |
Posted: 14 Dec 2021 at 6:44am |
Of the smaller engines I've balanced, most flywheels where fairly close as well as the pistons. Many of the rods needed some work. As for the BE/CE crankshafts that I've done, not one needed much. I try to run my engines around 4500-5000. In over 40 years I've never had one self destruct as I've seen engines by other people do. I would not think about building an engine for increase performance without having it balanced to match all its new parts together.
Edited by PaulB - 14 Dec 2021 at 6:44am |
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8457 |
Posted: 14 Dec 2021 at 11:41am |
I’m of no help but I have a 7080, so I’m curious…does taking material off the rods during balancing decrease the strength of them?
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5124 |
Posted: 14 Dec 2021 at 12:32pm |
Connecting rods have what are called balancing pads, the square area on top and bottom that you remove material from. You would not remove material from the beam other than smoothing the casting flash and polishing the beam.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3951 |
Posted: 14 Dec 2021 at 4:07pm |
new engines these days with new technogy in the machineing the componants very very close now that balancing ang blueprinting is almost a thing of the past, forthy year old stuff would be differant
DougG
Posted: 14 Dec 2021 at 4:36pm |
How much would it cost to balance an Allis 426? Guesstimate or ballpark figure, just curious,, also what do you call that when you add weight to the crank? Always Heard for more low end torque?
Edited by DougG - 14 Dec 2021 at 4:39pm |
tbran
Posted: 14 Dec 2021 at 7:38pm |
last one was $100/cyl. Ass to adding weight to crank - the only thing I have ever seen is drilling a hole in the crank throw and installing a plug of heavy metal to make it balance. Mostly on V8 cranks.
DougG
Posted: 14 Dec 2021 at 7:43pm |
Seems cheap enough then to have one balenced,,
DonDittmar
Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2516 |
Posted: 15 Dec 2021 at 6:33am |
Wasnt there a guy on here did some external balancing...........went by Pankey or something..........
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
ryan(IN)
Posted: 15 Dec 2021 at 7:42am |
There’s a name I haven’t heard in a long time.
ryan
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3074 |
Posted: 15 Dec 2021 at 9:05am |
I had my WD45 balanced when rebuilt a few years ago. Was around $400.
It runs smooth, but probably wasn't necessary. They removed quite a bit of material. I was at a Farm stock fun pull once and was idling on the track, and I heard the flagger mutter to himself, that thing runs like a sewing machine.
DonDittmar
Posted: 15 Dec 2021 at 5:10pm |
Man I thought I would have gotten a bigger reaction out of my pankey comment
***taps mic*** “is this thing on” 😂😂😂
Edited by DonDittmar - 15 Dec 2021 at 5:10pm |
allisbred
Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |
Posted: 15 Dec 2021 at 5:21pm |
I bought a wd-45 a couple of years ago with aftermarket pistons and fresh rebuild. Going down the road, motor has a harmonic imbalance with no load. It’s now on my list to drop the pan and check brg’s. Many have been rebuilt without balancing, may last for a while. Then again, it may not. |
cwhit
Joined: 12 Sep 2009 Location: Sigel IL Points: 1003 |
Posted: 15 Dec 2021 at 5:57pm |
Don, I,m laughing with you.
Joined: 11 Sep 2009 Location: illinois Points: 88605 |
Posted: 15 Dec 2021 at 8:36pm |
YEP... that WAS FUNNY..... have not heard him for YEARS !
HudCo
Posted: 15 Dec 2021 at 11:11pm |
thats been awhile
HudCo
thats been awhile
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5058 |
Posted: 16 Dec 2021 at 7:00am |
Sounds like a nightmare no one wants to relive ! I saw some posts of his recently on one of the Facebook AC sites. He is still giving out advice.
DougG
Posted: 19 Dec 2021 at 8:59am |
I think it was on here rumor was at Harvey when the rods came off the line they were just thrown in a basket, wouldn't think that's a good practice for critical internal engine components! What brand pistons and bearings did AC use ? Just curious
ACjack
Joined: 13 Sep 2014 Location: Peoria, Arizona Points: 277 |
Posted: 19 Dec 2021 at 9:37am |
They were not just thrown in a basket. The finished rods where sorted into four groups by their weight and placed into a steel tub using dividers and a rust inhibiter between the layers. This was for all part numbers. They used several suppliers for pistons, rings and cylinder sleeves. Two that come to mind where Bonalite (spelling?) and sealed power. Some time around the 70's they started to use components from Japan. For the main and rod bearings I recall they used Clevlite brand.
DougG
Posted: 19 Dec 2021 at 9:57am |
I gottcha, thanks for the reply ACJack- was hoping you would reply as you were right there ! Was just something Ive heard/ rumor about the rods ;
