Anyone balancing engines....
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Topic: Anyone balancing engines....
    Posted: 13 Dec 2021 at 11:23pm
at overhaul?
8070 / 7080 higher Rpm engines?   We have no idea if it pays - but the last two 426 engines we had balanced came back with an unbelievable amount of drilling and grinding, especially on pistons and rods.  Speed shop said they had never worked on components that much out of balance....
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 5:35am
I believe they balanced our 7060 when we overhauled it. It’s the smoothest running 426 I’ve been around.
ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 5:51am
Back in 1978 when I built a puller, the machine shop said the rods were the worst part of the imbalance on a 7030 engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 6:44am
Of the smaller engines I've balanced, most flywheels where fairly close as well as the pistons. Many of the rods needed some work. As for the BE/CE crankshafts that I've done, not one needed much. I try to run my engines around 4500-5000. In over 40 years I've never had one self destruct as I've seen engines by other people do. I would not think about building an engine for increase performance without having it balanced to match all its new parts together.
Edited by PaulB - 14 Dec 2021 at 6:44am
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 11:41am
I’m of no help but I have a 7080, so I’m curious…does taking material off the rods during balancing decrease the strength of them?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 12:32pm
Connecting rods have what are called balancing pads, the square area on top and bottom that you remove material from. You would not remove material from the beam other than smoothing the casting flash and polishing the beam.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 4:07pm
new engines these days with new technogy in the machineing the componants very  very close now that balancing ang blueprinting is almost a thing of the past,   forthy year old stuff would be differant
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 4:36pm
How much would it cost to balance an Allis 426? Guesstimate or ballpark figure, just curious,, also what do you call that when you add weight to the crank? Always Heard for more low end torque?
Edited by DougG - 14 Dec 2021 at 4:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 7:38pm
last one was $100/cyl.  Ass to adding weight to crank - the only thing I have ever seen is drilling a hole in the crank throw and installing a plug of heavy metal to make it balance. Mostly on V8 cranks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 7:43pm
Seems cheap enough then to have one balenced,,
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2021 at 6:33am
Wasnt there a guy on here did some external balancing...........went by Pankey or something..........LOL
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2021 at 7:42am
There’s a name I haven’t heard in a long time.
ryan
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2021 at 9:05am
I had my WD45 balanced when rebuilt a few years ago. Was around $400.
It runs smooth, but probably wasn't necessary. They removed quite a bit of material.
I was at a Farm stock fun pull once and was idling on the track, and I heard the flagger mutter to himself, that thing runs like a sewing machine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2021 at 5:10pm
Man I thought I would have gotten a bigger reaction out of my pankey comment
***taps mic*** “is this thing on” 😂😂😂
Edited by DonDittmar - 15 Dec 2021 at 5:10pm
1968 D15D,1962 D19D
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2021 at 5:21pm
I bought a wd-45 a couple of years ago with aftermarket pistons and fresh rebuild. Going down the road, motor has a harmonic imbalance with no load. It’s now on my list to drop the pan and check brg’s. Many have been rebuilt without balancing, may last for a while. Then again, it may not.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2021 at 5:57pm
Don, I,m laughing with you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2021 at 8:36pm
YEP... that WAS FUNNY..... have not heard him for YEARS !
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2021 at 11:11pm
thats been awhile
thats been awhile
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2021 at 7:00am
Sounds like a nightmare no one wants to relive !
I saw some posts of his recently on one of the Facebook AC sites. He is still giving out advice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2021 at 8:59am
I think it was on here rumor was at Harvey when the rods came off the line they were just thrown in a basket, wouldn't think that's a good practice for critical internal engine components! What brand pistons and bearings did AC use ? Just curious
ACjack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACjack Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2021 at 9:37am
 They were not just thrown in a basket. The finished rods where sorted into four groups by their weight and placed into a steel tub using dividers and a rust inhibiter between the layers. This was for all part numbers.
 They used several suppliers for pistons, rings and cylinder sleeves. Two that come to mind where Bonalite (spelling?) and sealed power. Some time around the 70's they started to use components from Japan. For the main and rod bearings I recall they used Clevlite brand.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2021 at 9:57am
I gottcha, thanks for the reply ACJack- was hoping you would reply as you were right there ! Was just something Ive heard/ rumor about the rods ;
