Anybody ever bought or made? |
| Author | ||
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9731 |
Topic: Anybody ever bought or made?Posted: 18 Jan 2020 at 12:04pm |
A power cord with a foot pedal. I’m going to be doing some light machining with a router. I’d like to keep both hands on it and have foot control. Also I built a long router table for work and it would be handy for that as well.
| Sponsored Links | ||
orange200
Joined: 30 Jun 2015 Location: New Hampton IA Points: 53 |
Posted: 18 Jan 2020 at 12:30pm |
We have a foot switch on our meat grinder. Works well. They can be bought at Cabelas or LEM Products. I think they are about $40. I am sure that they can be bought other places too.
Thad in AR.
Posted: 18 Jan 2020 at 12:37pm |
I will check Cabellas next time I’m there. Does it have male /female ends like an extension cord?
Thanks |
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 18 Jan 2020 at 1:29pm |
Make one: a bit of wood, a hinge, and an old 'foot operated' starter button. |
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 18 Jan 2020 at 1:33pm |
I picked one up at Harbor Freight with the 20% off copon for my meat grinder a few years ago. Has worked fine for me, rated for 15 amps. $13.99 minus 20% is $11.19, flat rate ship if needed is $6.99.
Edited by chaskaduo - 18 Jan 2020 at 1:36pm |
Joined: 11 Sep 2009 Location: illinois Points: 90822 |
Posted: 18 Jan 2020 at 1:37pm |
YEP.... that's what you want, one that STOPS when you lift your foot... Not one that toggles. The one from harbor Freight is probably cheaper than building one.
chaskaduo
Posted: 18 Jan 2020 at 1:41pm |
The Harbor Freight one toggles, step once and on, step on again for off.
Edited by chaskaduo - 18 Jan 2020 at 1:42pm |
Thad in AR.
Posted: 18 Jan 2020 at 2:38pm |
Maybe a trip to HF coming up.
Just curious but could one from a sewing machine control the speed of a variable speed router? |
Posted: 18 Jan 2020 at 4:30pm |
Elliot, it said it is a momentary switch so I looked at Harbor Freight and they make BOTH.. One is hold down for power, let up to stop... There is also a toggle version that looks just like that one that is once down ON, push again and its OFF............. GOOD TO KNOW !
Edited by steve(ill) - 18 Jan 2020 at 4:31pm |
chaskaduo
Posted: 18 Jan 2020 at 4:46pm |
Steve
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55282 |
Posted: 18 Jan 2020 at 5:35pm |
Dayton motors makes several, but a lot more $ than the HF ones...
DonBC
Joined: 12 Sep 2009 Location: Courtenay, BC, Points: 947 |
Posted: 18 Jan 2020 at 6:53pm |
I used a sewing machine to control a light bulb. It worked fine. You could probably find one at a recycle place for next to nothing and give it a try.
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 18 Jan 2020 at 8:12pm |
Try one of these
https://www.sciplus.com/foot-pedal-speed-control-120-vac-43485-p?gclid=Cj0KCQiA9orxBRD0ARIsAK9JDxRiCO0mNBs3HuaNNuQTQzHMaeIyHXwQzzLaBch9Y4COE8_wN6lqiQAaAsktEALw_wcB https://www.walmart.com/ip/SE-975PS-Foot-Pedal-Control-Switch-for-Compatible-Power-Tools/125802419?wmlspartner=wlpa&selectedSellerId=1220&adid=22222222227051875617&wl0=&wl1=g&wl2=c&wl3=311207261674&wl4=pla-563906662928&wl5=1028036&wl6=&wl7=&wl8=&wl9=pla&wl10=113500236&wl11=online&wl12=125802419&veh=sem&gclid=Cj0KCQiA9orxBRD0ARIsAK9JDxQ59HJopDSUXulVzxW79IJNy2sLSmAw9U9HU1BxgH4J4fXYn-NAypYaAqm1EALw_wcB https://www.amazon.com/Operated-Controller-Woodworking-Machine-Piggyback/dp/B07VSF64RM/ref=asc_df_B07VSF64RM/?tag=hyprod-20&linkCode=df0&hvadid=343187910376&hvpos=1o5&hvnetw=g&hvrand=16056611500166833524&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1028036&hvtargid=pla-818401838139&psc=1&tag=&ref=&adgrpid=69721953515&hvpone=&hvptwo=&hvadid=343187910376&hvpos=1o5&hvnetw=g&hvrand=16056611500166833524&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1028036&hvtargid=pla-818401838139 |
omahagreg
Joined: 11 Sep 2009 Location: Omaha, Nebraska Points: 2809 |
Posted: 18 Jan 2020 at 8:14pm |
I have a momentary one on my drill press! Nice big 'pedal'! Love it! Problem is I got it at Sears...
Edited by omahagreg - 18 Jan 2020 at 8:14pm |
Greg Kroeker
1950 WD with wide front and Freeman trip loader |
mikedes
Posted: 19 Jan 2020 at 1:48am |
I use one on my router and tied it to an outlet that has both the vacuum and the router plugged into so both go on and off together
Mike d
Thad in AR.
Posted: 19 Jan 2020 at 6:23am |
Heck of an idea. 👍 I’m gonna do the same. |
Thad in AR.
Posted: 19 Jan 2020 at 6:27am |
You da man Ted.👍 |
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3312 |
Posted: 19 Jan 2020 at 6:54am |
Check the amperage of yoor router before you buy one. The first 2 Ted has listed are only good for 1.5 amps. The 3rd one says up to 1/2 HP motor. The Harbor Freight one says 15 amp.
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5061 |
Posted: 19 Jan 2020 at 9:30am |
I put a press and hold foot one on my drill press.
Dusty
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8981 |
Posted: 19 Jan 2020 at 12:06pm |
I don't get it....my router has switch in one handle so you always have 2 hands on it. What am I missing?
Are you talking metal not wood? Would make more sense. Edited by SteveM C/IL - 19 Jan 2020 at 12:08pm |
Thad in AR.
Posted: 19 Jan 2020 at 12:50pm |
It’s mounted under a table I made. It’s a long reach. In planning on using an end mill in another and milling aluminum in a jig. They recommend a foot pedal. |
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6126 |
Posted: 22 Jan 2020 at 7:18am |
I don't build them. I buy used surplus industrial footswitches.... heavy steel or cast iron ones, with industrial switch contacts, clean them up, wire 'em, and call 'em good. You CAN buy new surplus:
john(MI)
Posted: 24 Jan 2020 at 8:50am |
Nope, but I did make one with a thermal couple in line to use on my gas log blower. I also made one with a dimmer in the cord and a power strip on the end for the lites in all the little buildings in the Xmas village. So I figure I could come up with something. Changing the end on a sewing machine foot pedal cord would seem to be the easiest and least expensive if you got one layin around!
Ted J
Posted: 25 Jan 2020 at 8:30pm |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42269 |
Posted: 25 Jan 2020 at 10:50pm |
I have one on my drain cleaning snake - large unit with a 5/8 cable and 100' length , something you don't want to have get away on you .
Square D switch - should be able to find at any electrical supply house . Spring loaded OFF push down to power . |
DaveKamp
Posted: 25 Jan 2020 at 11:05pm |
Says fourteen bucks to my zipcode... but when I buy things from S-S, I usually get several things, and have the shipping costs spread over the whole lot.
