any trick to putting the pulley
Byron WC in SW Wi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Byron WC in SW Wi Quote  Post ReplyReply Direct Link To This Post Topic: any trick to putting the pulley
    Posted: 19 Apr 2010 at 1:54pm
shaft on a WC?
I took the plate off for the first time in probably 50+ years.  I have a pulley shaft that I'm going to try and use for hydraulic pump that I put in part way and it's tough.  I'm glad it is as it's going up against that gasket but I don't want to injure the gasket.  Is there a trick to putting it in?
The shaft was a little rusty so I wire brushed that a little and then washed it with oil.
Thank you,
Byron
This page was generated in 0.081 seconds.
