any thoughts on what |
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25548 |
Topic: any thoughts on whatPosted: 15 Jun 2020 at 7:35pm |
an eight foot bed from a 2005 Ford P/U would weigh? I'm figuring about 750
I am still confident of this;
Joined: 11 Sep 2009 Location: illinois Points: 90811 |
Posted: 15 Jun 2020 at 7:53pm |
Thats probably MAX.... more like 500 pounds... I took a 6 ft bed off a 2006 FORD... Took the 6 floor bolts out and you could "almost" pick up one end by yourself... I parked under open rafters in the garage and put a 1/2 ton comealong on the left front tie down and the right rear tie down and cranked it up a foot to roll the truck out from under... put a 1/4 inch rope on the other two corners to rafters to BALANCE so it didnt tip too much.... mine was access to the gas tank pump....... then reinstall bed.
Edited by steve(ill) - 15 Jun 2020 at 7:58pm |
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9731 |
Posted: 15 Jun 2020 at 8:01pm |
Well under 500 is my guess. I’ve pulled a few with one guy on each side.
den/southern illinoi
Joined: 11 Sep 2009 Location: Sparta, Illinoi Points: 2092 |
Posted: 15 Jun 2020 at 9:35pm |
Ask your local body shop. Bet they can tell you within a few pounds. Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor. |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25253 |
Posted: 16 Jun 2020 at 5:31am |
500 maybe...less if the crossrails are missing due to rust...... I flip them upside down with forklift(A-C !) and 2 helpers to put onto pickup for transporting when sold. 5' forks make it easy to remove and install. Always 'interesting' how the wind 'magically' appears when moving the boxes.... so be careful ! probably moved 100+ in past 10 years. Jay
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11401 |
Posted: 16 Jun 2020 at 3:10pm |
My son, his wife and daughter and I picked up my 1975 Ford 8' bed and set it on so I don't think it was 500 lbs.
