any thoughts on an 8070 FWA?
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: any thoughts on an 8070 FWA?
    Posted: 03 Mar 2010 at 10:24am
I've got a chance to buy an 8070 FWA, with the motor out of it (it broke a rod bolt and put a rod throught the block) for $8500. Sounds kind of steep, but supposedly has 80% tires on the back and 90% on the front, had the power shift gone through not long ago, cab kit, and is supposed to be pretty nice. Couple questions; #1 If I took the engine out of my burned up 8050, would it go right in and thus have an 8050 FWA, or is there something more to it.  #2 Would it be wiser to find and rebuild an engine to the 8070 specs, and how costly would that get?  3# should I find a used engine for it  #4 what's it worth when done? #5 any other thoughts on it what so ever?  Thanks for any input  Darrel
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 10:46am
i picked up a 7080 engine that slid into my 7040  .. slick deal ..only cost me 2500 for the engine .. .. sometimes you gota due what works !!
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
tominpa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tominpa Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 10:46am
I think the 8070  has the fluid balancer on the end of the crank like the 7080. Engine will probably fit but it probably wont have the 171 hp..
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 1:22pm
If the engine didn't get to hot in the fire. It should fit right in. Depends on what it was putting out for hp in the 8050. Would you get the pump injecter and intercooler with the bad 8070 motor? If the rest of the 8070 is ok other than switching motors it could be a good deal.
Brad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 5:14pm
Not sure on 8070, but on 7060 and 7080 they had a slower rear end.  This is due  to higher engine rpm's.  Engine would slide in and fit, might have a slower tractor.  I would be tempted to buy it.  Would be a cheap tractor.  I think 8070 fwa sell for 15-25,000.
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 6:58pm
I have several blocks for sale if interested $450 each Sounds like adecent deal to me Should be able to rebuild an engine for around 6-8000 buying used replacement parts ie block/ crank
MI8050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI8050 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 7:17pm
My 8050 is running 10% over stock with the new injection pump so should be 165hp approx.  I wouldn't hesitate to stick the 8050 engine in the 8070 at all, it will last longer turning slower in my opinion anyway.   It would make you a good tractor for the money.
Dave King View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave King Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 8:47pm
Unless you need all the power you can get, putting the 8050 engine in it would work well, I think.  I think the crank is different in the two motors, but the rest is pretty similar.  The rear end should be pretty well the same, but the 8070 has a bigger 3pt and PTO like the 7080, the speeds should be the same, not counting the 8070's engine turned 100 RPM faster.  Like MI8050 said, you could turn the pump up and get pretty close to the stock numbers of the 8070.  If you need more power, you might try looking for a junked N6.
clint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 9:20pm
why not a cummins repower?
Our farms stuff: agco gt55, AA 8775, 8765, 6080, 185, 180, 175, 170, d15, d14, d14, wd, wd, wd, g, F3, L3, R62
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 10:28pm
the 8070 FWA has the same speed rear as all 8050's.2WD 8070's switched to same(faster) gearing @ser# 2662. your 8050 engine will be a simple bolt in.just leave it alone and have a good HD 8050 FWA .stick your side panels on it and no one will know the difference.should be able to swap the 2-speed pto also.
This page was generated in 0.313 seconds.
