Any restorers in southern Mich for a WD |
Docrock117
Topic: Any restorers in southern Mich for a WDPosted: 12 Jul 2025 at 1:41am |
Looking for some help finding someone for a restoration of a WD, believe it’s a 1949 purchased by my Grandpa new then ( 1 owner ). Live in southern Michigan, south of Kzoo.
jvin248
Posted: 12 Jul 2025 at 9:39am |
Serial number is on the back of the rear end casting, left side, Starts with "WD" then number. Look up on tractordata dot com for build sequence. That's the easiest source I found before when I was looking. WD I have, bought three years ago, was built within two weeks of the one on the farm growing up. Post some pictures of the tractor and condition you are starting with. . Edited by jvin248 - 12 Jul 2025 at 9:39am |
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1333 |
Posted: 13 Jul 2025 at 12:21am |
If you could get it over here I could probably do it… only a 8.5 hour road trip….
Would love to do another WD. But that would be a long road trip. |
Docrock117
Posted: 13 Jul 2025 at 7:27pm |
here are 2 images I just took. The first is a number I found between the transmission and the metal box to contain the battery. If this is the serial number it makes it a 1955 wd45, is that correct. The sticker/ label on the front only says WD. uploads/25750/image0.jpeg
Docrock117
Posted: 13 Jul 2025 at 7:28pm |
here is a shot of the tractor itself.uploads/25750/image1.jpeg
Dave (Mid-MI)
Joined: 12 Sep 2009 Location: Hemlock, MI Points: 576 |
Posted: 13 Jul 2025 at 7:34pm |
That is a casting number. The serial number is stamped into a flat pad on the vertical surface of the rear housing above the lift arm crossbar. Sometimes you have to scrape a bit to make the number readable.
Posted: 13 Jul 2025 at 7:40pm |
Late 1952 or 53 curved stick "WD" not a "WD-45".
Docrock117
Posted: 13 Jul 2025 at 8:19pm |
that’s what I always thought which is why that number confused me. I’ll go back out to the barn and see if I can find the number again
Posted: 13 Jul 2025 at 8:23pm |
Just above the lift arm shaft on the LEFT side close to the square headed setscrew for the left brake. WDxxxxxx.........should be 127000 or newer.
Docrock117
Posted: 13 Jul 2025 at 9:45pm |
I just don’t see anything there? uploads/25750/image0_2025-07-13_21-44-12.jpeg
Posted: 13 Jul 2025 at 10:12pm |
Need an electric wire brush to get rid of all the rust and barnacles. It is stamped and has to be clean to see it.
Docrock117
Posted: 13 Jul 2025 at 10:16pm |
ok, will give that a shot in the morning. Thanks for all your help!
55allis
Posted: 13 Jul 2025 at 10:40pm |
Doesn’t look to be in too bad of shape!!
Does it run? Even looks like original paint and decals. |
Docrock117
Posted: 13 Jul 2025 at 10:51pm |
bit of a long story but last time I started it it ran but could only get it into reverse. It had been kept in barn its whole life that my grandfather built for it. Then in 2016 we had a 22” wet snow event and the roof collapsed. There is a slight dent in the fuel tank from that but no other major visible damage. Problem then was, didn’t have anywhere to put it so it sat outside while I had barn demo’ed and new barn built but that took about 8 months. I traveled a lot for work so it has just sat there. Battery is cashed and the fuel leaks as soon as I open butterfly valve. Tires also need to be replaced. I have it up on blocks at the moment. Tires are at least 40 years old. So it has not run since 2017. I’m now retired and would like to give it life again.
Posted: 14 Jul 2025 at 6:30am |
I'm not near my tractor but it looks like (in the book) the serial number is just ABOVE that square headed setscrew.
Edited by DrAllis - 14 Jul 2025 at 6:31am |
Docrock117
Posted: 14 Jul 2025 at 4:28pm |
ran the wire brush across it. I’m at the point I’m afraid to go much farther as I’m not sure if I will remove the pitting or the ser number first. I can see pretty clearly WD 13_739. I believe the other number is a 4. The area is pretty pitted.
jvin248
Posted: 14 Jul 2025 at 7:25pm |
13xxxx serial number puts it in the 1953 WD production series. Some WD45 features were added ahead of time, like the "bent shifter" and other features short of the WD45 engine. But maybe you have that or it was upgraded. Photo of the other side of the engine could reveal. If it has a plate behind the mag or distributor or a solid casting with a boss. So you could have a very interesting model. . . |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55219 |
Posted: 14 Jul 2025 at 8:33pm |
Dust it with some chalk...
Alex09(WI)
Joined: 15 Mar 2012 Location: CECIL WI Points: 1777 |
Thanks(1)
Posted: 14 Jul 2025 at 8:53pm |
Welcome to the forum! Family tractors are great projects! They are worth spending the money on. A&W Tractor can do any mechanical work or complete restorations. We just dropped 2 tractors off back in IN that we worked on, one was near La Porte. Looks like you can take either ferry across to us or go through Chicago. We can also pickup/deliver.
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
