any one own a white 6175
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: any one own a white 6175
    Posted: 21 Jun 2023 at 3:36pm
anyone know anyting about one  and what would the cause of the front wheel assist be intermitant .   clutch pack, piston seals,  hyd. valve,  electrical ? .    the guy that is buying it says the rest of the tractor runs drives and looks like new 5000 hr.s .    i would probley be the one doing the repairs
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2023 at 5:02pm
I know it takes oil pressure to release/disengage the FWA clutch which is in the front axle I think. So, whenever the engine is OFF, it is in 4-wheel drive. It is in 4-wheel drive whenever you hit both brake pedals at the same time for 4-wheel braking. So what I'm saying is no electrical power to the front axle and it should be locked in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2023 at 11:20pm
i will bet there will be some clutch problem ,discs going bad  other than that how is the rest of the tractor i kind of like the field boss series after running a 2-105
I M Fedup View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote I M Fedup Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2023 at 8:22am
Be aware the 6175, the other 6100 series, and their orange cousins the 9600 AGCO tractors all shared some common failure items. I was with an AGCO dealership when they were sold new so I got pretty familiar with some of them. The PFA, as they call it, was definitely one of them. At some point in production AGCO recognized an issue there and did a quiet update on the clutch assembly with larger bearings in the area that supports the clutch assembly in its housing. A failure in that bearing area can affect the sealing rings that help direct hydraulic oil flow to disengage the front wheel drive clutch pack.
Should you actually get that deep into it, be aware of the change as AGCO didn't actually publicize it at the time. We just replaced them on an as needed basis. I would imagine by now any replacement parts available would be the larger bearings, shaft and housing required, but still, you never know. I haven't been into one in years, so I don't have any idea of the current parts availability.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2023 at 10:51pm
i havent been on here for a few days but i was guessing that it would be somthing like that.        it is never anything on the out side of the housings when it gets to me,   somone has allready fiddled with every thing on the outside till its all ready striped ,bent or missing
