Any Mauser action fans on here
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: Any Mauser action fans on here
    Posted: 17 hours 50 minutes ago at 5:36am
I have a question.
I recently bought another Mauser in 22-250
I plan to add a filler in the back of the mag well.
Where would I find a short action spring and follower for this project?
Could I cut down the factory follower?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 15 minutes ago at 6:11am
So are working with either a Rechambered action or Re-barreled?  Mag well is likely for an older 7 or 8mm?
I own a Spanish Laguardia Rechamber to 7.62 x 51(.308), does not appreciate some projectile styles, Round Nosed especially.  Bolt throw at times will also eject a new or next cartridge rather than feed it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 36 minutes ago at 6:50am
Yes it’s an old WW2 98 large ring Mauser.
iOS been rebarreled to the 22-250
I ordered a magazine filler to shorten the depth(front to rear) of the mag well. I’m looking for a shorter spring and follower which are also shorter front to rear. The filler goes in the rear of the mag well.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 26 minutes ago at 11:00am
Seems like you will need a different ejector as well to deal with the shorter brass.
Lots of good info in the gunsmithing section at www.castboolits.com
