Any information on input Hd-5
BFC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BFC Quote  Post ReplyReply Direct Link To This Post Topic: Any information on input Hd-5
    Posted: 6 hours 27 minutes ago at 12:56pm
Any insight or information on changing the seal, gasket. on the input shaft to transmission of HD-5.
1951 Model
Thanks for looking and your response.
Thank you
Les Kerf View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 33 minutes ago at 3:50pm
I have yet to replace the input shaft seal on an HD5 but I did extensive re-work on the shifter, and I can state that just checking the oil in the transmission would be easier if I were a trapeze artist.
Best wishes on your project Big smile
gemdozer View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 57 minutes ago at 4:26pm
You need to removed the drive shaft and removed the input shaft yoke and pull the gasket seal,2ring seal and boot assambly
BFC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BFC Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 10 minutes ago at 5:13pm
Thanks for your response to question.
I had the fuel tank off of the tractor, so it was easy to fill the transmission with oil.
When I had reinstalled the fuel tank and finish putting everything back in place. I notice oil leak around the input shaft.
 Would it be possible to replace the seals without removing the whole transmission?
Are replacement parts easy to find, by using HD-5 parts number?
Thank you
