Any general info on AC 7030
acplowboy45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acplowboy45 Quote  Post ReplyReply Direct Link To This Post Topic: Any general info on AC 7030
    Posted: 20 Jun 2017 at 1:17pm
Looking at 7030 and would like some input out there about the likes and dislikes on a 7030. Thanks
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 2:06pm
PD or PS? Lots of opinions there. The search engine here is kind of funky at times. I have the best luck with Google. Try entering Allis Chalmers 7030 Unofficial Allis and see what happens.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 2:52pm
7030 will be PD only...
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 3:22pm
We have a 7030 and a 7050 and really like them both. Good machines for us. Had the 7050 since the late 1990's. The 7030 was bought with a couple scored pistons so it didn't get used until we had it overhauled a couple years ago. Operates the same as the 7050. The 7050 has been trouble free for me for all these years other than an alternator and steering ram ball joints and bushings being replaced in one front spindle because of no grease zerk thereby no grease by previous owner. I've put about 1300 hours on it only and it's at around 5500 right now but those have been pretty much trouble free hours. I did put an air ride seat in it and that was a big plus. I guess some complain about them being hard to get in and out of the cab but it's been no issue for me. The hydraulics are super for a 1974 tractor and the cab is fairly quiet. I have replaced a shift cable and a clutch cable in the 50 and replaced the pivot bushings for the foot clutch linkage in the 30. I really like them both. With regular service (on time oil changes, daily greasing etc) they should last a long time for us.
Edited by Lonn - 20 Jun 2017 at 3:24pm
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 3:23pm
PS the only complaint I will register is that some gears are about the exact same speed as others so the 20 speed PD is really only about 16 speeds but that was as good as any in it's day.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 3:43pm
If you get rid of the OEM steering wheel and replace it with one from a black belly tractor or Gleaner combine, the in/out of the cab will be easier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 6:34pm
That's a great point there !
Plowking77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Plowking77 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 7:19pm
Really good tractor,, pulled a 5-16 John Deere plow a lot better than the neighbors 4440. Never had much trouble with it,, only complaint was the seat was kinda plain and like mentioned above the steering wheel made it fun getting out sometimes. Compared to r 7020 it was way more tractor. It was one of tractors dad said we should have
keep,, traded it for an 8070..which was a hell of a step up lol..
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 8:24pm
Had a 7030 new, way ahead of its time, I think a real good tractor but they are already 40+ years old so you have to be the judge.
This page was generated in 0.333 seconds.
