Any Ford 7.3 Techs Here? |
DennisA (IL) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ridott IL. Points: 2074 |
![]() ![]() ![]() ![]() ![]() Posted: 10 Oct 2018 at 11:22pm |
I'm having a repeat issue which three diesel techs have not been able resolve. A bad oil leak from the pedestal base. It will pump out 2-3gals in 20 miles. O-rings replaced as well as a new pedestal. Any help please!
Thanks & God Bless
Dennis |
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5145 |
Need a boat anchor?👻. Who nees a V8 anyway? There are straight 6s out therethat run forever👍
Les Royer ![]() Orange Level ![]() ![]() Joined: 25 Dec 2014 Location: Carson, Iowa Points: 5593 |
I'd say either your new orings slipped out of place or the oil is coming from somewhere else.
I still gots my A/C but it's clear out in the barn now.
I assume you already know that there are orings between the pedestal and the turbo. There are also plugs on the back of each head with orings that can leak. And there is a metal tube on the right head, intake side that sits in a metal holding bracket , with the tube going to the rear of the cylinder head. That tube can get a hole worn in it from that holding bracket.
Pumping out a large amount of oil, it's probably coming from the high pressure pump. There is a kit that has new o rings and fittings for the high pressure lines. Usually what happens is one of the block off plugs on the HP pump backs out a bit and then the o ring fails. Anything that leaks in the valley runs to the back and can look like it's the pedestal leaking. While you have it apart, look at the fuel tubes to and from the fuel filter housing. The right hand line to the RH head can wear on the bracket to one of the intake bolts. I've seen them wear through and make a big fuel leak. There's also a kit to replace all of those fuel line seals.
Every time the pedestal o-rings are replaced the oil leak stops for a time. Some times 2 months some times 2 days. Just don’t know why.
Thanks & God Bless
Dennis |
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12230 |
Full disclosure, I don't know diddly crap about the specifics of your issue.
Just a "general knowledge" thought though here, I wonder if the threads are good where you're bolting stuff together?
Edited by Tbone95 - 11 Oct 2018 at 12:47pm |
farmboy520 ![]() Orange Level Access ![]() ![]() Joined: 22 Jun 2016 Location: Beason, IL Points: 553 |
I know it might be a stupid question. Are they using the right kind of o-ring?
Red Bank ![]() Orange Level Access ![]() Joined: 18 Apr 2018 Location: Germanton NC Points: 1051 |
I agree with Farmboy and will add are they torquing the pedestal bolts?
Torqueing and rechecking after a warm up cool down cycle.....kinda part of what I was askin' too.
Are you replacing the pedestal with one that still uses the exhaust back pressure valve? Cause, you guessed it, there are orings there too. Visit Riff Raff deisel. They got a pedestal that deletes the back pressure valve in it's entirety. Hey, it's one less leak to have to worry about.
shameless dude ![]() Orange Level ![]() ![]() Joined: 10 Apr 2017 Location: east NE Points: 13607 |
riff raff???? lol, another good name for a ferd!
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34220 |
There is a valley pan on the 7.3 diesel that CAN and many DO leak, there is a PCV system grommet in that pan that also age hardens has that been looked at? It is retained by the intake and ONE Allen head plug style fastener, they DO come loose.
Edited by DMiller - 13 Oct 2018 at 8:40am |
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3938 |
having done many 7.3 fords i would go with what brian jasper says will probley have to remove the pump to get to the last oring that needs replacing
There is no valley pan on any 7.3 Powerstroke, never has been. I haven't seen an indirect engine for many years now so I can't really say about them. Aside from the HP oil pump and turbo pedestal, the only other possible place oil could leak in the valley would be the lift/transfer pump used from 94 to about 96. Afterwards they used an electric pump and the hole for the lift pump is closed off with a cup plug. There is also no PCV system in the valley either. There is an oil separator on the left side valve cover only.
Heavy truck applications might be different, but the pickup engine isn't built that way.
Sorry it’s been so long. I forgot to inform everyone what was found. The pedestal “O” s were leaking again. This time they replaced the pedestal as well. It hasn’t leaked a drop since.
Thanks & God Bless
Dennis |
