another wd to d17 engine cross
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: another wd to d17 engine cross
    Posted: 06 Oct 2023 at 12:47pm
will wd oil pan work the d17 gas engine
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2023 at 4:39am
They have different part numbers, but the gasket set is the same and the early D17 used the same oil pump as the WD, so I'd think so.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2023 at 7:16am
A D-17 gas oil pan is shaped inward on the right side to accept the starter right tight alongside the pan. A WD pan won't work in a D-17 chassis because of this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2023 at 10:42pm
i am going to use the d17 engine with the wd flywheel and bellhousing
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2023 at 10:43pm
1958 tractor
