Another tire blow out…………
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: Another tire blow out…………
    Posted: 10 Dec 2024 at 5:07am
on our tow dolly. This is the 3rd blow out in less than 7,000 miles, 2nd time the blow-out as totally torn off the plastic fender and lights. ST205/75R14, load range D is the one that blew yesterday. Always kept at proper psi, no dry rot or cracks. Have never had anything heavier than a 2004 Ford Taurus, yesterday was hauling a Honda CRV. What brand of ST tires have others here have decent luck with? TIA.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2024 at 7:31am
What is your air pressure in the tires?
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2024 at 8:32am
when I was pulling a camper I had too many ply separations with ST tires.  Switched to LT tires and nary a problem after that.  They were LR E and I ran them at 80psi which was what was max for the E.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2024 at 8:37am
How fast are you driving? A lot of cheaper trailer tires aren't speed rated over about 55.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2024 at 12:40pm
Sidewall stamped for 65 psi, that’s right where they are at.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2024 at 12:43pm
65-70 on the open highway, was only about 1/2 way on a 175 mile trip home.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2024 at 2:13pm
Check the manufacture date on the tires. Someone may be selling you old tires that have been stored in a warehouse for too long.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2024 at 3:01pm
   I dont like running full pressure, especially on a hot day.    Do they make an E tire in that size?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2024 at 3:59pm
Definitely was not a hot day, temp was mid-50’s.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2024 at 4:02pm
Sad to say and sounds wasteful but at Six to Seven years REGARDLESS of Tread Level, the tires on my trailers GO AWAY.  Learned that from a Tire guy that was looking at nearly New Looking Trailer Tires were Date Coded eight years, NO WARRANTY to start, one threw a tread where the match to that on other side blew apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2024 at 8:09pm
Yes you are absolutely correct. Tires years ago lasted for many years. Now you have to throw away after a few years. And we call that green!!!!! Lol.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2024 at 9:06pm
On my tri-axle low boy for hauling dozer and backhoe I wet to LT tires on 16" rims as same size as pickup - no problems with them . Hauled my old D6 a few times but being over width and overweight stayed close to home .
  Son bought 4 new ST for his tandem trailer - of the 4 / has replaced 3 in year of using it
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2024 at 9:14pm
I think i might be running 45 psi, not 65 psi in the tires.. BLOW OUTS for no reason are due to excess pressure. ... the "D" tire at 65 psi is rated for over 2000# each.. I doubt the front end of that car weighs 2500 #...... 45- 50 psi would be adequate..
Edited by steve(ill) - 10 Dec 2024 at 9:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2024 at 2:38am
Caution with that steve as the tires under load flex far too heavily, causes them to build heat at low air pressure actually degrading the rubber compounds.
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2024 at 8:02am
I would agree Dave, if you drop the pressure to 25 psi..... A  "D" rated tire set at 45 psi would have a fairly rigid side wall... Dont think it would be a  problem... I believe the 65 psi is the problem WITH the Blow outs.
Edited by steve(ill) - 11 Dec 2024 at 8:03am
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2024 at 8:21am
i just put all new 16inch 14ply tires on my gooseneck trailer a few weeks ago only have fifty miles on them so far
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2024 at 10:26pm
The reason why tires blow without having an overload, overpressure, or serious bruse or cut, is contamination.  Remove the remaining tire fragments, and send them to a lab for analysis, you'll find that there's some contamination inside the tire that caused the failure.  Contamination not only results in weakening of the tire, it causes rubber inside the tire to flake off into a dust which is rather flammable.  Frequently the contaminant is either an inappropriate tire mounting lubricant (i.e. motor oil or grease, rather than the water/soap based for-purpose swab lube), or some flammable substance used to ignition-inflate the tire.  This is a deadly practice, and should NEVER be done.
Running at reduced pressure isn't a particularly good thing, unless the tire is totally unladen.  Tires that run pressure too low will generate significant amounts of heat from the added contact patch's chord of flexure.  Eventually, this heat increases tire pressure internally, but not by much in comparison to the heat that occurs between the layers of rubber and impregnated belting.  Once inter-belt friction has worked up the temperature, belts delaminate, the rubber between becomes  detached in layers, and more friction occurs, more heat develops, and eventually the tire blows and shreds.
Cheap chinese rubber (and the US equivalent 'artificial' rubbers) are lousy in comparison to what was available before 1980.
Any one of these circumstances will cause a confounding failure trend.
This page was generated in 0.075 seconds.
