Another problem with the L3
bakwoodsfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Topic: Another problem with the L3
    Posted: 31 Oct 2016 at 6:17pm
She is doing great with the speed-up sprocket on, but I have a LOT of clean beans in the return. No matter how I adjust the sieve or chaffer or fan speed. I have took out the sieve and checked the pan underneath for holes, but no holes. It almost seems like the beans are falling off the sieve straight into the return auger? Is that possible? I have changed everything I can think of including travel speed up and down to no avail. HELP
Brad
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 6:49pm
Normally, too much clean grain running back around the tailings elevator means the lower sieve is closed too tightly, or you are driving too fast. Now, if grain isn't being taken away by the clean grain auger fast enough, you could have the same thing happen. So, you could have auger flighting missing on the clean grain auger, or something blocking the grain from getting to the (front) clean grain auger, like the blank that covers the perforated floor under the sieve?? You say you've removed the sieve and looked. The chaffer is on the top and the sieve is on the bottom. Which one did you remove??? I think you need to remove both to see what is going on. If you adjust the chaffer (1 1/8" short finger) to 1/2" opening and the lower sieve to 3/8" opening and have the air at "5"ish , it should work and have minimal tailings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 7:09pm
It has the long finger chaffer and sieve, I have removed both and tried running it with the pans covering the perforated floors removed. Both the one under the sieve and the one on the bottom(thinking it would save me from all the weeds I have been running through her). With the long fingers I should not get a perfect sample, right? But I have the cleanest beans around at the mill, just worried the return auger will stop up solid because of all the beans returning. When I cut the head off to unload the beans just pour out the front because the cylinder is throwing them forward.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 7:48pm
WHAT about clean elevator chain, In backwards, paddles worn out, mouse holes in them.
Check board or divider in clean elevator. Check cleaning fan for bent blades or twisted.
Shut separated off before it gets cleaned out and check where beans are piled up.
I'm with Dr. Sounds like clean grain auger is worn out.
Have saw wheat do that when blank was not put in under sieve.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 8:23pm
I know the fan is fine, I'll check the flighting on the clean grain auger. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 9:35pm
The perforated panels must be clean and not stuck up, so things can't slide down them.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 10:33pm
I caught the fan drive belt slipping thus slowing down the fan, shoe and overloading the tailings a few years back.. but that was in corn...
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 11:09pm
I used to run the "cookie sheet" in the A2 but this F2 didn't come with one.My panel looks like a porky pine after beans. Backwoods,I don't know how much experience you have with conventional Gleaners but you always have some beans in the return.Grab a handfull and see if it's as bad as it looks.
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 11:10pm
I was cutting with the L3 the other day. Same thing way to much good clean beans coming over the return. Had it opened way up !!!! Got to looking, and the rear shaker arm had came out and trapped itself in the angle bracket. Therefore the shoe was sitting on a slope letting it over load one side. I doubt that's it, but l wouldn't have guessed it either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 5:50am
Steve, It is as bad as I think. It will almost fill up a average drinking glass with clean beans on every paddle.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 8:26am
Is the front of the sieve in the lowest position? Are all the seals in place and in good shape? My L2 has never done that but I do have new augers and elevator chains. My tailings used to over load with trash and then the slip clutch with chatter but a new auger and elevator chain solved that problem. From here I think it's a worn auger or elevator chain on the clean side or a hole or missing seal. Your not getting trash so I'd say it's not anything to do with the fan......... or the fan is stuck wide open......... I run my fan nearly wide open but I'm in heavy green stems too.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 5:57pm
I looked it over real good this evening, the paddles look good, clean grain auger looks new, the sieve is in the lowest position. It looks like to me the beans are dropping off the sieve into the return auger, maybe its supposed to have a shield there? Or maybe the fan is just still to high and blowing the beans back to the return auger when they fall off the sieve? I had this problem last year in 10-15bpa beans but when I got into some 30+bpa beans it cleared up. I'm in 40+bpa beans now and it's still doing it. I can run like this because it is not throwing beans out the back and giving a good sample.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 6:07pm
This is what I was running through my ole girl(early year pic).
See if you can find the beans(they are there I promise)
[/IMG]
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 6:40pm
You need a Scour-Kleen! Lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 6:47pm
Not hijacking the thread, but what "blank" are you talking about? Is that something specific for beans? I ran an M2 this summer and it was delivering a lot of wheat back to the cylinder, and it was plugging the elevator at times. (I'll check the other things like the clean grain cross auger and elevator chain.)
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 7:33pm
Creston, on my L3 it has a flat sheet bolted under the sieve and on the floor of the shaker pan, you remove these and it is perforated to allow small weed seeds to escape before the return auger. You can only run them in beans or corn the holes are to big for wheat.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 7:42pm
On a corn soybean special, the plate under the bottom sieve that directs clean grain to clean grain auger is drilled full of holes (like a wheat screen). There is a blank sheet that slides over the holes when you cut small grain. Without that blank in wheat, alot of wheat will fall through into return.
 This sounds like what is happening  with backwoods farmers combined in beans.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 9:06pm
No he needs a disc !!!! Disc before planting will take care of marestail . Are those not ill beans ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 9:33pm
Oh ok! Thanks for the explanation, guys!
This page was generated in 1.285 seconds.
