another electrical problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: another electrical problem
    Posted: 06 Dec 2023 at 5:59pm
Dang went to town and only had HIGH blower.....
came home, found out why.....
Think I'll write Ford about it...only lasted 26 years. Had a spare,'popped' it in...took an hour. It's in a nearly inaccessable area under the dash, passenger side...oh well. Replcing the door window 'privacy' glass with 'A/C' glass was EASIER !
So that's TWO electrical problems..........I'm waiting.....for ...... #3.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2023 at 6:37pm
Can't imagine why that doesn't work
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2023 at 6:45pm
air flow thru the duct keeps it cool... Looks like you got RAIN or HUMIDITY  !! Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2023 at 8:13pm
humditity..... truck has A/C, still icy cold after 26 years too !
replacement came from a '99,sitting on shelf for 10+ years, it was like 'BNIB' condition,just a royal PITA to install.....
masking tape between 9mm socket and screw really helped reduce number of 4 letter words....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2023 at 4:34am
Far easier than the beating I took to change a damper driver in my 2010 Impaler(4 deer two turkey), also has instructions as to installing what a whiz bang garbage idea, first fail warranty, this one did last close to 12 years.
My 99F250 looks similar to that for rust but on the Outside!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2023 at 7:28am
Glad you didn't have to take the whole dashboard out. Most things on vehicles these days are easy to replace ONCE you finally get to them if you can even get them without major disassembly of the vehicle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2023 at 8:03am
ha ha...
reminds me...
I need to replace the STRING that connects the 'PRNDL' indicator TO the gear shift lever
THAT will be an all day event,as yeah, 1/2 the dash has to come off....
might, MIGHT be a 'winter ' project, maybe, umm, I'll have to think about it,later,...
'funny' how no one here has offered to do it....jes complain about what gear's the truck in....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2023 at 9:01am
Have changed a Few, not usually the cable but the plastic ear it clipped onto, easiest to drop the Column.  Otherwise, shift all the way down count three back up.
Edited by DMiller - 07 Dec 2023 at 9:01am
