Another DIY tire question |
JW in MO ![]() Orange Level ![]() ![]() Joined: 16 Feb 2010 Location: South KC Area Points: 2670 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Jul 2023 at 6:51pm |
Managed to ruin the valve stem on a brand new $50 inner tube, bought a valve stem repair patch from Miller Tire then got to thinking, do you put the repair over the old stem or put a patch over that and install it in a new spot?
Codger ![]() Orange Level ![]() ![]() Joined: 23 Dec 2020 Location: Utopia Points: 2458 |
I usually cut the old stem out of the tube, patch over the hole and install the replacement stem into the tube at the same angle as the one removed but in a different place on the tube.
That's All Folks!
That worked, I did double patch the valve stem hole, 1” patch covered with a 2”, just made me feel better. |
It has always worked for me in the past and happy you had success!! No problems with double patching at all.
That's All Folks!
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 42018 |
Had a tire shop hot patch new valve stems onto tubes for road grader and they went over the old patch area with the new stem - just one area of tube and reused .
200Tom1 ![]() Orange Level ![]() ![]() Joined: 03 Jun 2019 Location: Iowa Points: 1232 |
22 years owning my tire shop, we always put the new stem over the old stem hole.
Edited by 200Tom1 - 10 Jul 2023 at 12:50am |
