Another D17 NF question
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: Another D17 NF question
    Posted: 14 Nov 2019 at 8:04am
Guys,
Seen this NF for sale...notice the circled parts...are those specific to NF or are they the same for WF? In other words if I got a NF, would those have to be included?  I think not but want to be sure....thanks
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2019 at 8:29am
Appears to be the power steering components that are circled.  On the D14 those would be on a power steering bolster, but not on a manual steering one.  I'm not sure if those parts can be installed on a manual one.  The pump is not show and would be needed for it to work.
Those parts would not be needed  to be included, but you sure would enjoy driving the tractor if they were!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2019 at 8:39am
Thanks....was wondering if perhaps those PS parts would be slightly different, say like the mounting holes for instance as compared to same parts on a WF.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2019 at 8:40am
If you have a wide front with power steering you only need the narrow front pedestal.
The rest is the same.
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2019 at 9:09am
On my d17 they appear to be the same on the wide front axle also.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2019 at 9:19am
Should all fit both wide and narrow fronts
Edited by Lonn - 14 Nov 2019 at 9:20am
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2019 at 2:41pm
Thanks fellas for the confirmation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2019 at 7:20am
If you install a single front on a D series tractor, you will need a bearing holder. The fork is the same as the WD-45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2019 at 8:27pm
What is the bearing holder you speak of?
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2019 at 12:49am
On my D14 when I switched it to PS, the last rod in the steering column was different.  I don't know if that is the same on a 17 or not.  Just thought I would mention it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2019 at 7:01am
The rod in a D-14 NF has a coarse spline and the D-15/17 have a fine spline. D-19 is 2" taller but the shorter ones will fit on. The bearing holder is about 6" tall and contains two bearings. It bolts to the main casting the same as the narrow front but has a flange on the bottom for the single front fork. I don't have a picture in my computer but have a few in the shed. Very hard to find. Not for sale!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2019 at 5:27pm
Hard for me to picture in my mind. Wish I had a part number so that if I get a NF (what I want to do down the road) it would include this part.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2019 at 12:22pm
Bearing holder attached to the main steering block from a D-15 Single front
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2019 at 4:58pm
Calvin,
You talking about the highlighted part?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2019 at 7:30pm
The complete casting up to the bolts shown. About 6" tall. The flange you have highlighted is where the single front fork bolts on.
