Another D17 NF question |
   TomYaz
      Quote   Reply
     Topic: Another D17 NF questionPosted: 14 Nov 2019 at 8:04am  |
   Guys,
  Seen this NF for sale...notice the circled parts...are those specific to NF or are they the same for WF? In other words if I got a NF, would those have to be included?  I think not but want to be sure....thanks  |
   john(MI)
      Quote   Reply
     Posted: 14 Nov 2019 at 8:29am |
    Appears to be the power steering components that are circled.  On the D14 those would be on a power steering bolster, but not on a manual steering one.  I'm not sure if those parts can be installed on a manual one.  The pump is not show and would be needed for it to work. Those parts would not be needed  to be included, but you sure would enjoy driving the tractor if they were!
   TomYaz
      Quote   Reply
     Posted: 14 Nov 2019 at 8:39am |
 Thanks....was wondering if perhaps those PS parts would be slightly different, say like the mounting holes for instance as compared to same parts on a WF.
   Calvin Schmidt
   Joined: 11 Sep 2009 Location: Ontario Can. Points: 4555  |
      Quote   Reply
     Posted: 14 Nov 2019 at 8:40am |
   If you have a wide front with power steering you only need the narrow front pedestal.
  The rest is the same.
   nella(Pa)
   Joined: 11 Sep 2009 Location: Allentown, Pa. Points: 3133  |
      Quote   Reply
     Posted: 14 Nov 2019 at 9:09am |
   On my d17 they appear to be the same on the wide front axle also.
   Lonn
   Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817  |
      Quote   Reply
     Posted: 14 Nov 2019 at 9:19am |
   Should all fit both wide and narrow fronts
  Edited by Lonn - 14 Nov 2019 at 9:20am  |
  Wink I am a Russian Bot  |
   TomYaz
      Quote   Reply
     Posted: 14 Nov 2019 at 2:41pm |
   Thanks fellas for the confirmation.
   Calvin Schmidt
      Quote   Reply
     Posted: 15 Nov 2019 at 7:20am |
   If you install a single front on a D series tractor, you will need a bearing holder. The fork is the same as the WD-45.
   TomYaz
      Quote   Reply
     Posted: 15 Nov 2019 at 8:27pm |
 What is the bearing holder you speak of?
   john(MI)
      Quote   Reply
     Posted: 16 Nov 2019 at 12:49am |
   On my D14 when I switched it to PS, the last rod in the steering column was different.  I don't know if that is the same on a 17 or not.  Just thought I would mention it.
   Calvin Schmidt
      Quote   Reply
     Posted: 16 Nov 2019 at 7:01am |
   The rod in a D-14 NF has a coarse spline and the D-15/17 have a fine spline. D-19 is 2" taller but the shorter ones will fit on. The bearing holder is about 6" tall and contains two bearings. It bolts to the main casting the same as the narrow front but has a flange on the bottom for the single front fork. I don't have a picture in my computer but have a few in the shed. Very hard to find. Not for sale!
   TomYaz
      Quote   Reply
     Posted: 16 Nov 2019 at 5:27pm |
 Hard for me to picture in my mind. Wish I had a part number so that if I get a NF (what I want to do down the road) it would include this part.
   Calvin Schmidt
      Quote   Reply
     Posted: 17 Nov 2019 at 12:22pm |
   Bearing holder attached to the main steering block from a D-15 Single front
   TomYaz
      Quote   Reply
     Posted: 17 Nov 2019 at 4:58pm |
   Calvin,
  You talking about the highlighted part? ![]()  |
   Calvin Schmidt
      Quote   Reply
     Posted: 17 Nov 2019 at 7:30pm |
   The complete casting up to the bolts shown. About 6" tall. The flange you have highlighted is where the single front fork bolts on.
| Forum Jump | Forum Permissions  ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum  |
