Another B question
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Topic: Another B question
    Posted: 03 Nov 2010 at 4:51pm
What oil goes in the transmission and rear gears on a 39 B with out hydraulics or PTO?
Thanks,  Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2010 at 5:04pm
You can use about any gear lube you want including the hytran fluid that guys use with hydraulics. If you have an unrestored tractor that might tend to weep hytran fluid because of old gaskets etc., use a 80-90 gear lube.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2010 at 5:45pm
When we sold them they came from the factory with 140 Gear Lube.  However, in very cold climates it was proved that it was not efficient lubrication since the oil would freeze.  I agree with Charles.  Use 80 wt gear oil.
Take good care of my favorate.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2010 at 6:46pm
According to the ITT manual capacity is 6 qts is that about right?
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2010 at 7:54am
Both the B and C  Allis manuals call for 20W year round. 6 qts (7 with PTO).
Change oil twice a year.
I think "Hy-Tran" would be a good choice in place of 20W motor oil.
Edited by Brian G. NY - 04 Nov 2010 at 7:55am
Lance/SC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lance/SC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2010 at 9:47am
Tim, if you don't have any problems with "wally world" some of their stores carry hy-tran in 7 qt jugs.  I have it in my B and CA.  Local stores quit carrying it down here but when I was at the GOTO at Gray, Tn in the spring I was in a Wal-mart store and on a hunch checked out the  oil area and lo and behold there it was on the shelf.  Picked up 1 for a spare.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2010 at 4:58pm
Thanks Lance/SC, I'll check out the local Wally.
