Ambac 100 pump
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 7:51pm
Ok. Kinda what I figured.   I did look under the cover again tonight and the droop screw is already gone.
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 7:52pm
Originally posted by Tenn allis Tenn allis wrote:
I have an 8070 it seems really lazy with the throttle response. I also have some a pumps what is involved with the conversion any idea of cost . Can this be done at a reasonable cost
To do the swap PROPERLY, you need to change out the front engine plate. I have tried the "adapter" from kcgrain. Dont like it at all. I've done both and will be converting the adapter tractor one over soon. And one needs a injection pump without the retarding plungers. Bending injection lines is the next fun part. It's a damn good swap to do, but I'm going to try a roosamaster on our 8030 soon. And putting together a roosa pumped n6 engine for our new 8050.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 8:01pm
I thought the retarding plungers would aid starting? Couldn't tell you whats in mine.Just know it starts on the first turn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 8:19am
You would think they would, but have a deere pump with them on our 220. When its above 40* it starts great. Below that, it just BELCHES smoke and coughs on fuel. Now the 8050 with the deutz pump, it has no trouble at all. I've tried high timing and low timing. Dont know why the allis's dont like the retarding plungers.
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 12:49pm
sWhich spring are you guys talking about to help the flutter? Our 8030 has had the pump sent off to fix a flutter issue. Got it back and it was good for 20 hours maybe and its back to doing the same thing. Tractor has good power, starts great, just has a real bad flutter when not under a hard pull.
Making a living farming with and working on Allis Equipment
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 1:05pm
Had this same trouble with our couple 8000 series. Have you ever replaced the fuel hose that goes from the fuel filter to the head of the pump? Not the hoses on the back of the pump, the one that goes to the front of the pump on the side.
RelianceWorks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RelianceWorks Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 1:59pm
Odd out of the 100+ 8000/7000 series tractors and Gleaner combines running with adapters not one has failed or had a complaint, yet the 1 adapter you bought has been plagued with problems? What exactly is not working PROPERLY on those adapters?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 2:15pm
Never said that it didn't work, it just isn't the best way to mount the pump. The proper way is to mount it directly on the front plate. Seems to me your still mad at me for having my 8050 engine build posted on here "showing" how to A pump these engines . Have a great day!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 2:31pm
Well, every engineer has reasons for doing something the way they did it.  Ease of installation might be one reason. Cost may be another reason. Reliability should be a reason. And a combination of these 3 and more reasons could have something to do with it.  You like your way, and that's great. But, it doesn't mean it is thee best and only way to do it.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 3:26pm
I detect a little friction Disapprove
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 5:53pm
If you take the top cover of the pump with the 4 bolts there is the fulcrum lever that attaches to the governor lever.   It's kinda hard to explain without a picture but there is a nut next you where the governor arm attaches that is towards the outside of the pump housing.   There is a spring between the governor arm and the nut. I've had to tighten this nut periodically to keep the flutter out. From what I've been told there are different governor springs that are down in the pump that are supposed to cure this problem.   I guess it is more of a problem in the powershift tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 6:08pm
ACFarmer here's a pic of the pump schematic.   The nut is located where the arrow is pointing.   There is a nut on the opposite side holding a cam looking piece. Don't do anything with that nut, just tighten the one next to the governor arm.   Tighten it enough to take care of the flutter but make sure the fulcrum lever still moves freely.   If it's too tight it'll really make the governor lazy. This schematic must be from a pump used on an IH because everything is on the opposite side of the ones used on the ac's. I've changed the fuel line on mine but it did not cure the flutter in mine. Hope this helps
Edited by HagerAC - 07 Nov 2018 at 6:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 7:17pm
Thanks. Gives me an idea on where to head with it. The flutter makes it annoying to run. And it is a powershift as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 8:44pm
Yes I know how you feel.   I had another forum member inform me on it and he actually came to our farm and helped me with mine.   We tried to loctite the nut in place that time but it never held.   Being its been too wet to do much here the last few days I took the time and tried to loctite it again.   Hoping it will hold this time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2018 at 7:11am
Takes a 7/16" wrench if I remember right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2018 at 7:20am
7/16 probably works. Its actually an 11 mm. Same size as the bolts for the top cover
Post Options Post Options   Thanks (0) Thanks(0)   Quote RelianceWorks Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2018 at 10:02am
No, your completely wrong about friction. Many people have mounted an A pump directly, but they didn't contact me to help them make it work afterwards. If you have it all figured out, then you spend the time and money and figure it out for yourself. Your the one that got upset because I wouldn't help you.
 Your statement was the PROPER way to mount is to bolt to the front plate, and that you tried the adapter and didn't like it, and will be converting it back. Your alluding that there is a problem mounting the pump with adapters.  Anybody is free to mount a pump anyway they chose but to mount on the front plate you have to take the plate off the tractor and have a machine shop locate and redrill and rebore the holes to make an A pump fit. To get the front plate off any 7/8000 series you have to take the cam out, which means you either have to get lucky enough to hold the lifters in place as you pull the cam, or remove the engine and flip it upside down to pull the cam remove the plate etc. I have met few machine shops that drop everything to locate and remount pumps, so your talking weeks at the quickest. The adapters on 7000 series just unbolt old rosa master pump, bolt on adapter bolt on pump, attatch new lines and your going. On 8000 series you have to remove the front cover and change the idler gear, then the process is the same as a 7000 series. Solid steel adapters, oring grooved so they dont leak, machine fit morris taper for the drive gear, timing pin is in the same spot. We made it as simple as possible. Many engines run adapters right form the factory to mount pumps, the 11000 series engine comes to mind.  Our kit allows the tractor to be converted in hours,direct mounting would be weeks waiting for the machine shop, unless your going to go buy another front plate, which is more expense, and machine shops charge by the hour, all the time they burn up trying to locate that pump your paying for.
Have a great day my friend
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2018 at 10:08am
I have had an A pump with a Relianceworks adapter running on one of my 8070s for 12 years now, no problem with the mounting.  Governor action is far superior to the rattletrap AMBAC M100 pumps.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2018 at 12:49pm
Most of us with these tractors just want to know:
1. Is it possible?
2. What is the cost?
3. How great (if any) are the benefits?
4. What is involved? (if we can do it ourselves... being farmer mechanics)
5. Is there any options or alternate choices that may be better/worse?
Hopefully, with all of those facts we can decide how to proceed.
We all love our tractors. Compared to the new ones they still are great!
We just want them to be a bit more responsive and maybe better starting.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2018 at 10:55pm
Originally posted by RelianceWorks RelianceWorks wrote:
we offer a complete kit to switch it to an A pump if you like
Got a link? Have an L3 with a dying pump.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
soggybottomboy View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote soggybottomboy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2018 at 8:50am
If a person had unlimited funding(which i don't),what would be the best pump that a person could install on an 8000 series tractor?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2018 at 9:15am
Actually, it is 7/16", those are American Bosch pumps, and all fasteners are standard, most are 1/4" coarse, some 1/4" fine.
