AM/FM Switch on C.B.Radio ??? |
BuckSkin
Joined: 12 Sep 2019 Location: Poor Farm Points: 1166 |
Topic: AM/FM Switch on C.B.Radio ???Posted: 08 Mar 2025 at 3:46am |
I am looking at a 40-Channel C.B.Radio that has a feature that I am totally unfamiliar with; it has an AM/FM Switch.
I may be totally wrong about this; but, the way it looks, one can choose AM or FM on any of the 40 channels. I have no idea which would be normal for a radio that lacks the ability to select; would normal be AM or FM ? When and why and under what circumstances would I opt for either AM or FM ? I have owned and used hundreds of C.B.s and have never seen nor heard of this feature before. |
ekjdm14
Joined: 20 Aug 2024 Location: Alsager UK Points: 987 |
Posted: 08 Mar 2025 at 3:58am |
In the USA you'll be on AM generally, not sure if FM has been legalised for no-licence there yet but I did hear something about it a few years back I think.
Over here in the UK we're the opposite way around, 27MHz/11Meters FM is our legal band, AM is illegal (although I do own some old Cobra AM rigs and have been known to earwig whatever skip I can pull in on a nice evening, just don't key up lol) Does the rig you're looking at have a little "27/81" logo on the faceplate somewhere? If so then it'll be designed for use on the UK band also.
Edited by ekjdm14 - 08 Mar 2025 at 4:04am |
BuckSkin
Posted: 08 Mar 2025 at 4:03am |
What I have been finding says FM was made legal in US in 2021; AM is still legal as well. One point I did read that may or may not be correct was that, if one has their switch set to FM, although they can hear them and probably hear them better/clearer, they cannot communicate with people who are on AM; to me, that would probably be a huge annoyance as the majority of radios out there are not yet going to have the FM ability. |
ekjdm14
Posted: 08 Mar 2025 at 4:10am |
That's correct, you can't communicate across different modulations. You might get some kind of bleed-over effect if the two stations were very close (within few hundred feet on good groundplane antenna, a bit like the garbled "donald duck" of sideband coming in on a mid band set) but otherwise the two are exclusive.
From experience, FM is definitely very much clearer and higher fidelity BUT very much less range-per-watt compared to AM, with zero chance of any "skip" (where you can hear folk clear across the country on a clear evening). One other advantage to running FM there, if you're communicating between a local network where you can all be on FM then you would be far less likely to get randomers coming in over the top of who you're actually calling (I gather channel 6 over there is quite ridiculous now & even 19 gets congested with folk who don't know how to take it up or down a few after making contact.
Edited by ekjdm14 - 08 Mar 2025 at 4:12am |
BuckSkin
Thanks(1)
Posted: 08 Mar 2025 at 4:20am |
So, in effect, by having an AM/FM switch, you are making a 40-channel radio into an 80-channel radio; maybe not technically, but practically, right ? Something else I read led me to believe that there are devices one can add on a straight AM radio to provide switchable FM ability; of course, as such things go, one could probably buy a new AM/FM radio for about the same money.
ekjdm14
Posted: 08 Mar 2025 at 4:31am |
That's the way I look at it yes. Having the ability to switch gives you the best of both worlds without having to have either another add-on (if already running a linear, don't need more wires trailing) or a whole seperate rig like I have.
Not sure on the add-on convertors, I'd imagine it's possible but like you say they're probably not cheap.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35678 |
Posted: 08 Mar 2025 at 4:41am |
Last radio I picked up has that option, push the channel selector in and switches to FM(Red indication on channel indicator), accidentally hit that one day swapping channels on the truck driven at work, has same radio, lost outbound capability but could kind of hear others. Pushed channel selector and back to AM and all normal. Know of no one around here using FM bands.
fjdrill
Silver Level Access
Posted: 08 Mar 2025 at 7:06am |
Come on all you truckers talk to Teddy Bear. Teddy Bear was AM only
ekjdm14
Posted: 08 Mar 2025 at 10:42am |
Aaaaaauuuudio, aaaauuudio, foe ten, foe ten...
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55278 |
Thanks(1)
Posted: 08 Mar 2025 at 3:07pm |
Did I hear a request? ![]() |
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6124 |
Thanks(1)
Posted: 10 Mar 2025 at 1:46am |
Having both AM (the historical 'standard' for US Citizen's Band) and FM modes, does NOT constitute having '80 channels'. It means you've got two different modulation types fighting over the same 'channel'... interfering with eachother. Let's do some basic theory here. A radio transmitter is a device which has, at it's simplest configuration, an oscillator. Like a BELL... it rings. It's ringing at a frequency much higher than what you can hear, but it's ringing... and it's not generating mechanical air pressure, it's generating a magnetic field that is alternating. Because of what it does, it 'disrupts' the magnetic environment around us. Most radio-frequency activity occurs between 540 Kilohertz (the bottom end of the AM broadcast band), and 5.0 Gigahertz (your cellphone's higherp-end Wi-Fi connection). Frequencies in the lower ranges tend to 'bounce' their way around the globe, while frequencies higher up tend to be line-of-sight. IF you take a coil of wire, and connect a circuit that can gather that disruption, you can hear the PRESENCE of a transmission. IF one end turns that oscillator on and off... and someone far away can HEAR that oscillator turn on and off, you can 'key' out a signal using the off-and-on... and you have radio telegraphy. Now let's say you increase the pitch of the 'note'... go up to 4.3 Terahertz... that's the visible light spectrum. Turn a light bulb on and off, and you're transmitting a radio signal by telegraphy... because light is electromagnetic, and our eyes CAN DETECT radio-frequency energy in the 4.3 Terahertz range!!! So turning a light on and off, is technically a radio transmission and reception method, and by turning it on and off, you place intelligability in the transmission. Two boy scouts with flashlights sending morse-code. Now here's where 'modulation' comes in. Continuous Wave (CW) is simply the circumstance of a signal being off or on. You can call it 'Morse Code', but technically, it's a Continuous Wave mode, that USES a series of short and long on-times, separated by off times, to yield a message. Radio guys refer to this as "CW". AMPLITUDE Modulation, is when the INTENSITY of the transmit energy is varied, to yield an intelligable signal... it's basically a circumstance where, instead of turning the light on and off, you turn it on, but you VARY the brightness (like, with a microphone) to pass some message from one side to the other. Frequency modulation, is changing the 'note' of the bell... or in the case of light, changing the COLOR of the light... and the message is sent through the change of color. -------------------------------------------- The amount of 'power' required to carry a signal, is highest using FM. It 'sounds' quieter, because the presence of static has no impact on the change of frequency that the reciever is looking for... but in order for information to be carried through, the modulation must swing the pitch up and down, such that any 'channel' above and below will be encroached upon... resulting in interfereance. AM requires significantly less power, and that power is focused on just ONE frequency, so you can have 'channels' much closer together than in FM. Then there's Single Sideband Suppressed Carrier, aka "SSB". SSB is an AM signal, but where the actual carrier frequency, and ONE HALF of the modulation waveform domain has been removed. The receiving station 'adds' the carrier and other sideband, to reassemble the intelligable signal. This means that all the transmitter's power is thus focused on the modulation envelope that remains... all the transmitter's power goes into the intelligable signal. As a result, SSB and CW carry much farther because of their higher efficiency... and they require less 'bandwidth' to do what they do. Finally, there's CW... which is the most effective at reaching out the farthest with the least amount of power. FM was approved by the FCC for use in the US, but it's a very foolish idea... very few 'cb operators' have a clue about how RF energy works... and in the modern 'free-for-all'' circumstance means everybody will be doing everything everywhere, walking on everybody else.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4077 |
Posted: 10 Mar 2025 at 7:17pm |
i dont know any thing about the am fm but i have a cobra ltd 129 in my service truck with upper and lower side band that kind neat once
DaveKamp
Posted: 12 Mar 2025 at 10:50pm |
When a radio is equipped with circuitry for upper and/or lower sideband, it will, by design, have a much better receiver... it will hear better, EVEN if you're using AM. It USED to be considerably more expensive, but from a manufacturing standpoint, adding the componentry for sideband operation is insignificant... to the point that if you open up and look, you just might find that the circuit board in your AM-only Cobra might have a section set aside for all those components... they might actually BE THERE, and just not 'enabled' for operation. Building things this way reduces the quantity of components a manufacturer must build and support... it's like cars fitted up with all the wiring for electrically-heated mirrors... but you didn't 'buy' the package, so the switches were replaced by 'blank' panels. I didn't put hard numbers in my description above, and in retrospect I SHOULD have, and as I was driving along today, I realized the 'easy' example was right in front of me. Turn on your AM broadcast band, and you'll notice the numbers are 1110, 1120, 1130, 1140... those are in Kilohertz... 1110 is 1.110 Megahertz... 1420 is 1.420 Megahertz. AM Broadcast stations are 'assigned' frequencies in the AM Broadcast Band at the 10,20,30... not the 15, 25, 35, etc., because the broadcast SIGNAL extends from 5 kilohertz below, to 5kilohertz above. IF they put a station on the 15 mark, or the 45 mark, etc., it would visciously interfere with the station 5khz above, and 5khz below. IN FACT... when they issue licenses, they look at the location, and power level of the OTHER stations on either side of a proposed new license, and set up spacing so that a station on say... 730, isn't placed on the air nearby a station on 740... because anyone listening to either, will get terrible quality from the adjacent frequency's signal. Now, with all that in perspective, the AM Broadcast signal is, by this explanation, about 10khz wide. 730 would occupy from 725 to 735. 740 would occupy 735 to 745. Seems kinda wide, yes? Well, if you narrow it up (and you can), the result is bad sound quality... like everybody's talking with pencils shoved up their noses, and a rag in their mouth. Remeber 'sideband'? Well, the space from the 'center frequency' to it's outer edges, is the side band. For 740, the 'lower' sideband occurs from 740 to 735. The UPPER sideband occurs from 740 to 745. If you add some fancy circuitry, you could chop off just one side (upper or lower) and suppress the carrier (which is why SSB is actually referred to as Single Sideband Suppressed Carrier) and get all the intelligability, with significantly LESS transmit power... because the RECEIVING set replaces the missing carrier, and converts the single sideband, into the equivalent of an AM signal. Now let's switch to FM Broadcast. Notice how the channels start around 87, and go up to 108? That station at 101.3 is 101.3 MEGAhertz... over 100 times HIGHER than your 1100 Kilohertz AM Broadcast station. Notice the FM Broadcast channels are in odd decimal steps too... 101.3, 101.5, 101.7... never 101.4 or 101.6. What this means, is that every FM Broadcast CHANNEL is 0.2 Megahertz WIDE. 0.2MHz is the same as 200 Kilohertz. The US AM Broadcast channel is 10 Kilohertz... there's 110 'channels' from 540khz to 1660khz. Notice a difference here? Yeah, FM is SIGNIFICANTLY wider... and the reason is simple- The FM signal is changing frequency up and down... it is naturally wider. IF one were to convert the AM broadcast band to FM, using the same concept, instead of 110 AM broadcast channels... You'd have just 5. How's this compare to CB? In CB, you have 40 channels spread from 26.965Mhz to 27.405Mhz, they're on 10Khz spacing, just like AM broadcast. Go to FM, and your channel spacing results in... FOUR channels. Just four. And when You're using FM, you're walking all over the users of TEN regular AM channels. And this is why people that understand radio technology say that arbitrarily opening up CB band to 'FM' is a foolish thing to do. The FM mode is much better suited to higher frequency operations (above 130Mhz), and that's precisely why MURS, GMRS, and FRS exists... with the added bonus that those higher frequencies are less prone to atmospheric noise, are SIGNIFICANTLY more efficient to utilize with shorter GAIN-type antennas necessary for vehicular operation... and they're allowed significantly more transmit power to boot. GMRS and FRS allows repeaters, too, and there's quite a movement to the growth of public GMRS repeaters. |
Les Kerf
Posted: 13 Mar 2025 at 7:21am |
As usual, Dave hits it out of the park ![]() Back in the mid-late 1970's I was an Avionics Tech (COMNAV) in the Marines stationed on a helicopter base in Tustin, California. The Marines were still flying outdated leftover junk from the Vietnam era, some of which had to have been designed in the late 1950's-early 1960's. Some of the equipment was transistorized, some was sorta hybrid with both vacuum tubes and transistors, and some was pure vacuum tube stuff. The helicopters had UHF radios (ARC-51) for air-to-air and air-to-tower communication, FM radios for talking to the ground troops, and HF (ARC-94) radios for long range stuff. I was primarily a RADALT (Radar Altimeter) tech, but I cross-trained on a number of other black boxes as well. On of those was the ARC-94 HF unit. The ARC-94 was probably the pinnacle of vacuum tube airborne radios; a veritable monster weighing in around 40 lbs (I forget the exact specs). It had a chassis that contained a complicated mess of mechanical gear trains that were servo-controlled to facilitate changing channels by mechanically rotating all of the various modules that plugged into the main chassis. They probably worked fine when they were brand new, but the wear and tear of constant vibrations, etc. made it difficult to keep those ganged tuning capacitors working properly across the full range of its 30,000+ possible channels. The ARC-94 had AM plus upper and lower SSB capabilities; minimum power on AM was 125 Watts RMS and Sideband had to be 400 Watts RMS minimum. At night time we would routinely contact Japan for radio checks. I can still remember keying the microphone "Yakota, Yakota, this is Hotel Michael Sierra One Six on eight niner eight niner requesting upper HF radio check, how copy?" A few seconds later we would hear the reply "Hotel Michael Sierra One Six this is Yakota on eight niner eight niner, copy fair and readable". Ah, those were the days! |
DaveKamp
Posted: 13 Mar 2025 at 11:04pm |
Ah, yeah- those were 'brute' machines... an Icom 706 Mk2G is what... 20yrs old now, and in about 4lbs, does everything the ARC did in range and mode... and a solid-state follower would lay out 600W PEP ...
It just wouldn't withstand an EMP... (not that I'd wanna be in a flying eggbeater when an EMP drifted through at the speed of light, but hey... ) Honestly though... I've got a dozen machines covering HF in my shack, there's a Yaesu FT1000MP with a 2k Henry, a Ten-Tec Omni VI+, with a Centurion, an Icom 745 with an SB220... and in the Boatanchor Rack sits a Motorola R390A, and in another rack, a Hallicrafters SX-101A atop a Central Electronics CE-100V phasing transmitter with a multiband amplifier built by W9AT John around 1960. The FT and the Omni VI+ have wonderful front ends... the VI+ is an incredible CW machine... the 745 is a very good all-purpose all-mode, very handy... but if you want fantastic sound quality on AM, follow the compass, ignore the weight... roll out the R390A... I'm convinced that it, and many of it's contemporary radio devices of it's timeframe were actually designed to help satisfy the US Navy's 'additional ballast' stability goals. Ships full of R390As could never 'capsize', because all those Permeable Tuned Oscillators kept the ships' keels firmly planted on the ocean floor at all times.
Edited by DaveKamp - 13 Mar 2025 at 11:08pm |
Les Kerf
Thanks(1)
Posted: 14 Mar 2025 at 9:51am |
When Viktor Belenko defected from the Soviet Union with a MiG-25 Foxbat back in 1976 the American media made derogatory references to the 'outdated' Soviet avionics equipment because it used ancient vacuum tube circuitry. We Marines were greatly amused by this ![]() I haven't kept up with modern communications equipment at all; I truly enjoyed working on the old stuff because it was challenging. We did troubleshooting and repair down to the component level on all of our equipment; this new stuff just doesn't interest me, it is mostly just throw-away. |
