Aluminum radiator
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Topic: Aluminum radiator
    Posted: 29 Jun 2025 at 8:33pm
Has anyone run one of these aluminum radiators? The one in my pulling tractor has sprung a leak. A original style radiator is almost double the price and I have yet to call about getting the original recored but from what my grandpa has told me that won’t be real cheap either
https://www.alloyworksplus.com/products/alloyworks-3-row-aluminum-radiator-for-allis-chalmers-wc-wd-wd45-wf-70228587-tractor?variant=a19f5fc0-e43c-420f-bf7a-35d1f44b2da7&gad_source=1&gad_campaignid=22335662584&gbraid=0AAAAAo2eqBOlvL2Dumoq1nG4LRnHjkYdO&gclid=EAIaIQobChMItfDWwYOTjgMV32BHAR16ixxmEAQYBCABEgLPn_D_BwE
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2025 at 9:41pm
A re-core is not the cheapest option, but it is the best and most reliable option in my opinion.  A local shop will guarantee their work and help you if there are any problems.  Amazon and e-Bay will not.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2025 at 10:45pm
A "puller" ?? Have you tried some good stop leak with water only for coolant??? don't need antifreeze in the summer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2025 at 12:55am
A little Solder Seal and straight water should do the trick if the leak isn't to big. If that doesn't work, save your money and have the original recored. That's probably a sure bet that it will last a loooong time....
Steve@B&B
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2025 at 3:54am
At 1/2 the price and using the tractor few hours as a puller I'd try the aluminum one.
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2025 at 5:34am
Guy supplied an aluminum radiator for a Wd at work. My brother put it in. He said stay away from them. They don’t fit quite right. He had to do lots of massaging to get it to fit. Quality didn’t seem that good. Buyer beware.
ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2025 at 5:40am
I have no experience with the W_ tractor aluminum radiators, however I have gotten one for a CA. The workmanship was very good, although when the Chinese changed the dimensions from inches to millimeters something got really fouled up. The fit WAS TERRIBLE and I could barely get the radiator shroud swelled out to go over the radiator. I'd never buy another. From my experience Shoup has about the best quality and price that I've come across. Contrary to general belief, the ones I've gotten for CAs have been made in Ireland not China.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 23 hours 14 minutes ago at 6:02am
Use Griffin Radiator. You will be happy.
That's All Folks!
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 37 minutes ago at 9:39am
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 5 minutes ago at 10:11am
If it's only being used for pulling & the leak isn't too horrendous I'd try the doctor's suggestion first of all. I've used a couple tablespoons of ground black pepper to great effect in a number of radiators & it doesn't tend to clog up things as badly as proprietary stop leaks.
Stuck Farmer
This page was generated in 0.191 seconds.
