Aluminum head spark plug change |
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8367 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Aug 2019 at 7:09am |
Is it better to change spark plugs in a car with aluminum heads warm? Or would cold be better?
Edited by DougG - 21 Aug 2019 at 7:19am |
chaskaduo ![]() Orange Level ![]() Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Recommended cool here, and more info.
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5060 |
What happened to Champion Plugs? At one time they were good plugs, but they went down hill fast, somewhere around 1970.
Dusty
Alberta Phil ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3933 |
Probably when they moved production off shore to China!
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12236 |
Little trick I learned, the hard way:
I ended up cross threading a plug in an aluminum head. I was able to repair the hole without too much trouble because I didn't force it too far. Anyway....From that day forward, I always start threading a plug by putting it in an old spark plug wire boot that I've cut off the wire. It holds it tight enough to start threading, but will slip if it isn't threading in correctly. Even helps you holding it for easier starting.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24754 |
I had my local mechanic do my truck after reading HORROR stories about changing them, let alone you have to be an Olympic gymnast to do it ! I figured if HE screwed up, he'll fix PDQ as HIS hoist is MIA until my truck runs again ! As it was ,all 8 came out fine AND he fixed the exhaust bolts at the same time. Odds are real good I'll be dead and buried before truck needs another set done.... Jay |
Ray54 ![]() Orange Level Access ![]() Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4758 |
LeonR2013 ![]() Orange Level ![]() ![]() Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Also when you change the plugs on an alum. head it might be a good idea to put a recommended anti-seize on the plug. Leon
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54329 |
A length of vacuum hose, the size to fit over the wire contact of the SP is real handy, too. Specially for those real hard to reach plugs, you can use a longer piece of hose, spin plug with right hand and guide plug into hole, with left, or vice versa, if you is a lefty...
fixer1958 ![]() Orange Level ![]() ![]() Joined: 13 Feb 2010 Location: kansas Points: 2434 |
[QUOTE=Dusty MI]What happened to Champion Plugs? At one time they were good plugs, but they went down hill fast, somewhere around 1970.
Dodge Ram uses them in there trucks. I always replace what it took from the manufacturer. Get them from the dealer and says Mopar on them. Champion from the parts store. 30K plug change interval. 16 plugs on a Hemi. I never have a problem with them. Doesn't make any difference to me hot or cold for a plug change unless you are cooking some hide off. Edited by fixer1958 - 21 Aug 2019 at 6:49pm |
Only reason I ask this is on my Stratus one was terrible to get out,, started it up let it run a bit , got some heat in it and it back out smoothly,,
Dave H ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Central IL Points: 3591 |
Dang fixer, my Ford will go over three times that on plug change.
That's recommended for those engines. I think they are copper core plugs.
