alternator vs tach |
7060
Joined: 16 Sep 2009 Location: Missouri Points: 1148 |
Topic: alternator vs tachPosted: 12 Feb 2010 at 10:45pm |
I am having trouble with my tach maxing out at half throttle on my 7060. It hits 3000 when it should be about 1500rpm. It has a different alternator on it and when I got it the tach wire was off. If the alternator was bigger or different would that cause it? I also have a 7050 that the tach runs at about 500rpm wide open and 300 idleing. What would cause such a low reading? Any help would be great |
Denis in MI
Joined: 15 Sep 2009 Location: Norvell, MI Points: 832 |
Posted: 12 Feb 2010 at 10:58pm |
are the pulleys factory size?
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
7060
Posted: 12 Feb 2010 at 11:06pm |
They look to be the original size, but im not 100% sure. The 7050 and 7060 both have the same pulley. The 7060's alt was rebuilt a couple years ago. |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24776 |
Posted: 13 Feb 2010 at 7:17am |
Sounds like the new alternator has a double the number of poles compared to the original.That would give you exactlry twice as many 'counts' per rev. This could be confirmed ny knowing the part number of the original and 'new' alternator. A slightly different pulley size(say 2 3/4" vs 3") would give a slightly higher or lower reading. hth Jay
