alternator pulley config for use with power steer |
Matt WI WD45
Joined: 20 Nov 2018 Location: Brookfield, WI Points: 31 |
Topic: alternator pulley config for use with power steerPosted: 14 May 2019 at 4:05pm |
Hi folks...
Looking at switching the WD45 I bought last fall to 12V. The PO had it set up for 8V and the battery was pretty well shot an don't feel like investing in a new 8V battery. 12V conversion in non-power steering applications seems pretty straight forward. Looking at my setup with the power steering, looks like the alternator fan would be right where the PS belt comes close to the generator (looks like it almost runs between the generator pulley and the generator. What's the solution? Run without the alternator fan for this relatively low current draw application? Machine up or cobble together a pulley extension that will space the pulley out about an inch from the fan? Rig up a PTO-driven alternator? ;) Matt |
Nuubie, WD45 Quick-change front-end, ps, AC500 front loader
Posted: 14 May 2019 at 4:08pm |
I've done many D-17's without an alternator fan for the same reason and have never had any issues.
joelsplace
Joined: 07 May 2019 Location: Northlake TX Points: 74 |
Posted: 14 May 2019 at 5:44pm |
If you keep the battery on a maintainer like a Battery Minder it will take a lot of the load off the alternator if it sits much between use and your battery will last a lot longer.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7530 |
Posted: 15 May 2019 at 11:21am |
Keep your old generator, just get it rewired for 12 volts. I have done that with mine. A local auto electrical shop can do that, or give it to Steve at B&B.
DougS
Posted: 15 May 2019 at 12:21pm |
Take the fan off, as Doc suggested. If the alternator is only going to charge the battery and run the lights and ignition, you won't need the cooling from the fan anyway.
