Alright machinists I got a ?
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: Alright machinists I got a ?
    Posted: 06 Nov 2018 at 6:18pm
I had to make a down rod for an outside on the porch ceiling fan. The homeowners wanted large Pipe so they decided on 1.5” I made a wooden beam in the ridge (vaulted ceiling) and used pipe flanges on each end. The electricians gave me a decorative weather proof box to mount to the bottom flange. The flange was much larger than the box so I cut a short piece of pipe and threaded it in the flange and chucked it in the lathe. I tried every kind of bit I had hss and carbide and I could hardly touch that stuff. I wound up grinding it down. It was made in China and just wouldn’t cut.
Edited by Thad in AR. - 06 Nov 2018 at 7:12pm
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 6:29pm
Who knows what's in Chinese metal, especially if it is a casting or forging.... They just chunk old files, bearings, or other harden steel in the mix.  I've have been sawing angle (imported) and all the sudden on a cut the saw blade just stops cutting, stop saw and look at teeth all just blunted off as in hitting a hard spot.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 6:43pm
In 2000 I was cutting malasian steel and that crap would be cutting along with the torch and all of a sudden it would blow up in your face... cut around the spot and go on.. Grind it afterwards to smooth it off and it would shower thin very short sparks. Some thought maybe it was like tungsten, and high carbon steel was suggested too...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 7:11pm
Called 'Bastard' steel as contains about every type of steel known to man.
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 7:15pm
 HMMmmm,,thats odd,,,I've never come up on that ,,you would think it prolly bein cast,would cut like butter,,,But,,there ain't nuttin that will stand up to the trusty 4 1/2" grinders,,,is there,,??
 I made me a "Shade Tree Clamp" to use one of my 4 1/2" grinders on the ways of the lathe,,kinda like a poor man's mill, sorta a crude thing  but HEY,,it works for what I got to do,,,,,Wink I'm gonna get me a small mill one of these days,,,,,,Clap
Les Royer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Royer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 7:34pm
Well Thad, since  all the Cheby guys said the Ferds went to China as scrap, I'd say you got yerself part of an old 49 F-150 thar.......
Just go steal.....I mean borrow a chunk of steel from one of Shameless's trucks. It'll be like cutting butter.
Edited by Les Royer - 06 Nov 2018 at 7:36pm
I still gots my A/C but it's clear out in the barn now.
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 7:34pm
Did you have the cutting tool set at the proper hight? Not above center.
Edited by nella(Pa) - 06 Nov 2018 at 7:36pm
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 7:59pm
I agree with Nella, check center. If it's cast I'd try turning a little slower than recommended with hss and see what that does
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 8:03pm
I adjusted it I started at just below center and adjusted down a few tries. I even tried an HSS parting tool from the end and it wouldn’t do much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 8:10pm
Time fer the tool post grinder...Wink
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 8:56pm
Les is feeling better. Wink
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 9:10pm
You've assessed it correctly-  it's crap metal... they don't sort, or process-clean the scrap, and do very little to remove impurities to the pot before making a pour.
It's not unusual to run into a hard spot in quality steel every so often... steels based on virgin iron tend not to have it often, but it still CAN happen, particularly in tubing, where there's a welded seam that gets quenched a little different from the rest... but most of the imported stuff, it's just an alloy of ignorance... whatever they threw in.
I have three metal-cutting bandsaws in my shop arsenal, and there's plenty of times when I pull out the abrasive chop-saw, or an air cutoff tool, or the 4" or 8" grinder.
God gave us some awesome machine tools... and for everything else, there is abrasives.  ;-)
Edited by DaveKamp - 06 Nov 2018 at 9:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 9:14pm
Set your tool on center and put a small radius on the tip. Make sure you chuck it as close to the chuck as possible to limit deflection. Slow, small cuts until you get through the hard spot
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 3:29am
 Ditto what Tyler says about tool settings,,,Clap
