Allis-Chalmers Transformers
angledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote angledge Quote  Post ReplyReply Direct Link To This Post Topic: Allis-Chalmers Transformers
    Posted: 02 Aug 2016 at 12:32pm
I need to remove several old Allis-Chalmers transformers from an abandoned mining site in Central City Colorado. I am trying to learn how much they weigh. I have their serial numbers - can I look up information regarding these transformers? If so, where?
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2016 at 1:28pm
I doubt that you will find anything out on that,,, hook them up and seewhat the boom does! Sorry wish iI could be of more help
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2016 at 3:21pm
You might find information about them from the local power company where they are located now.
jbtaglio View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote jbtaglio Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2016 at 3:41pm
Go to www.swgr.com/store/oil-filled-transformers.aspx/mfr/ALLIS CHALMERS.  Highlite the specific transformer, and the weight is on the specification line.
irlbeck A-C'S View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote irlbeck A-C'S Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2016 at 4:55pm
Check the name plate for that info. It should tell all. Pole mounted transformers can be from around 300lbs to over 1000 lbs.
Other pad mounted transformers can be from several hundred lbs to 10's of thousands lbs and even bigger. Some are so big it takes special heavy haul trucks and permits to carry them. On the larger transformers it should show a dry weight and oil filled. If you can't find the weight, find out how many phase it is. Single or 3 phase. How many kva and volts it is will be a starting point. Also a lot of the older transformers had pcb's in them and special precautions as well as other documentation or handling procedures will need to be taken.
B,C,CA,(2)WC's,(4)WD's,(2) WD45'S, 45Diesel, (2)D12'S Series 2, D12 Hiclear,(2)D12 Series 3, HD3, D17NF (3)D17 Series 4 Diesels, M-100 Grader,8550,A few Lawn tractors lots of other AC stuff
Post Options Post Options   Thanks (0) Thanks(0)   Quote angledge Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2016 at 5:24pm
Thank you for all the replies! I actually got ahold of someone at Siemens (they took over Allis Chalmers' transformer business line at some point) using their toll-free number (1-800-SIEMENS). Based on the serial number I got off the transformer's face plate, he was able to give me a weight.
I have three 50 kVa single-phase transformers. Empty of oil, they weigh approximately 700 pounds each.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2016 at 11:35pm
angledge. if you are wanting to sell them, I wouldn't be surprised if someone on this forum would be interested in purchasing them.  Might at least pay more then scrap price.
Allis Express participant
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2016 at 5:40am
Remember all those were PCB filled. IF the oil is gone thats a plus. IF guys want them, remove the core and use just the tank for whatever you want to do. Copper core, seo some money there but they may ask where tey are form. The name plates should say a weight and a MFG year. We take the old ones down and install new ones and are right back out replacing due to the new ones being junk from the start. Ive seen old 5kva AC's run right with a new 25KVA transformer. Sure they will get warm, but not fail.(usually):)
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
This page was generated in 0.219 seconds.
