ALLIS-CHALMERS G
Dan Hauter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Topic: ALLIS-CHALMERS G
    Posted: 28 May 2025 at 2:15pm
I have G# 7602. It's been stored in a shed with the battery removed. Unfortunately I don't remember how the battery was installed before. I bought a new 6 volt battery & installed it with the positive terminal toward the starter. I hooked up the positive terminal. When I attempted to hook up the negative terminal I got a lot of sparking. I reversed the battery & I'm getting less sparking but it still seems like too much to me. What am I doing wrong?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2025 at 2:18pm
6 Volt: + ground PERIOD, plain and simple. I've never known anything 6 volt to be -ground.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2025 at 2:48pm
Sparking should not happen no matter which way the battery is hooked up.  Check your wiring.  You are grounding out somewhere.
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 8:06am
Ignition switch on?
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 8:27am
... unless someone changed it over the years.
The systems can be easily changed from positive ground to negative ground by changing the two small wires on the coil, switching the wires on the back of the ammeter and "flashing" the generator.
If the wire going from the coil to the distributer is on the positive (+) side of the coil, it is positive ground. If the wire going from the coil to the distributer is on the negative side, it is negative ground.
I agree that only way you are getting sparks is if you have something in the system grounding out.
