Allis-Chalmers ACOP 30 C - NEED INFO
LadderMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LadderMan Quote  Post ReplyReply Direct Link To This Post Topic: Allis-Chalmers ACOP 30 C - NEED INFO
    Posted: 29 Jul 2014 at 9:29am
Hey everyone...
I am cleaning out an old warehouse, and I came accross an old lift truck with a decal that says "ACOP 30 C". As I know absolutely nothing about these things, I was hoping someone might be able to shed some light on what I have here...
The model # is: ACOP 30 BCA 24V
Serial #: ALQ522313
Attachments: 42 Forks
Type: F
with 3848.5 Hours
I also found a battery charger with this.
Like I said, I have no idea about these things. For all I know, it has been sitting in a corner for at least 5 years, but worked within the last 10 years. I was hoping to find out if this unit would be worth trying to fix? Should I scrap it? Should I try to sell it?
I appreciate all help offered on this. I can get pics as soon as I have a better lightsource in the warehouse...
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2014 at 9:43am
If it has no major failures great. I'm assuming it's electric so It is probably ACE 30. If the battery has been sitting that long probably junk. They generally have ge controls in them if it still has an Allis can try adding water and charging the battery and see if it'll work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2014 at 2:42pm
Is this a stand up machine because 24v is odd for a forklift.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LadderMan Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2014 at 3:20pm
Yes it is... I was cleaning around it, I will probably have pictures and an update on if it works or not in a couple days...
This page was generated in 0.174 seconds.
