Allis wd45 distributor gasket none like mine
Orangeypeach99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orangeypeach99 Quote  Post ReplyReply Direct Link To This Post Topic: Allis wd45 distributor gasket none like mine
    Posted: 20 Dec 2024 at 6:26pm
Mine has the same holes as all the other ones I've found online but my distributor has a guide stud on it any help to find gasket?
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2024 at 7:18pm
If I understand correctly you just need an additional hole in the gaskets you're seeing online in order for it to work in your setup?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2024 at 5:20am
Don't think I've ever seen a gov housing with a locate dowel.  Either way, just punch the extra hole you need in the gasket and bolt it on.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2024 at 7:24am
If the governor housing (NOT the distributer !!) has a small line-up dowel, that is for the timing gears backlash !! Each engine may be a little different and yes, the gasket, which has no holes, gets that hole punched in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2024 at 9:16am
I bought a set of these years ago and I use them all the time:
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2024 at 7:21am
X 2 wjohn!
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2024 at 7:59am
X3 wjohn
I drilled a bunch of various sized holes part way in to the side of a piece of 2 X 3 and mounted it to the wall.
Now my punches are always within reach'
G
This page was generated in 0.046 seconds.
