Allis WD stalling laugh of the day
Popps View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Popps Quote  Post ReplyReply Direct Link To This Post Topic: Allis WD stalling laugh of the day
    Posted: 15 Mar 2011 at 11:49pm
Finally got the WD going like it should. It would start right up and idle fine but when given more gas or put under load it would die. I cleaned(several times) the fuel line, sediment bowl, lower carb etc. and still had the same results. I finally decided I would do one more cleaning and if that didnt work I would get the carb rebuilt. This last time I removed the float and stuck above the needle was a little peice of trash. This little bit of trash was just enough to stall it out at operating speed and to throw me off of the problem. I just couldnt figure out why a tractor that seemed to be getting enough fuel would act up like it was. While I dont claim to be mechanical this is one lesson I wont soon forget!
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2011 at 7:15am
Patience wins again, along with stick to it and look for the details...does make you feel good when you can find the solution
