allis WD narrow front
jmrehn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmrehn Quote  Post ReplyReply Direct Link To This Post Topic: allis WD narrow front
    Posted: 29 May 2025 at 6:32am
The pedestal with the hubs is my original, the other one is the replacement I bought from forum member mike,both from WD's,same casting #'s but cast in different spots.Don't know if I want to lower the front of my tractor that much.
53WD
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmrehn Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 6:46am
Mine is a late WD,Is my original more like a WD45 pedestal?
53WD
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 6:57am
Welcome to the Forum. Odd that they would have the same casting number unless the extra piece at the bottom is separate. The difference in height might not be that noticeable once you get it installed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 8:08am
Something don't add up. I think yours has a spacer added at the bottom. Will have to look at mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 8:31am
The short one is NORMAL. Yours ain't. It even has a longer shaft to match the added in spacer. maybe a Thompson Hi-Crop accessory ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmrehn Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 8:54am
My original intention was just to do a swap, my wobbly loose, for Mikes much tighter pedestal.
Now I am curious.
Going to do some further disassembly on the long one to see whats up.If the parts are not to worn maybe swap the spindle blocks.
I was going to take that one apart to see how bad of a job it would be to put in a new lower seal. Practice before taking the one I want to use apart.
Maybe I have a super rare million dollar WD. I wish.
53WD
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 10:31am
Thompson cane tractor conversions were wide fronts & factory high crops were typically either single front wheel or wide fronts. I've never heard of a tricycle high crop. Your original part looks factory...kind of a mystery?? Kip
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmrehn Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 11:01am
Here is the long one disassembled,spacer and a longer spindle shaft? there were no shims like the book shows
Edited by jmrehn - 29 May 2025 at 11:08am
53WD
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 6:58pm
I'm throwing darts in the dark here: Is it possible that someone at sometime had reason the raise the front end and made a longer shaft and the spacer???
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 7:52pm
If it had 13.6 x 38 rear tires it would level it out.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2025 at 5:50am
I thought this was used on a mounted corn picker.
http://lonsallischalmers.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmrehn Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2025 at 6:20am
I posted the same pictures to a facebook Allis group, and several suggested that.
53WD
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2025 at 7:04am
Another "It ain't factory AC" turns out to be factory AC
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2025 at 7:25am
If you're into pulling this tractor, your hitch height will be different!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2025 at 8:38am
So, if you can find the parts book for a 33 picker, if the book is new enough, these parts should be in there.
Robert Musgrave View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Musgrave Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2025 at 8:47am
On the second picture, cart has air cleaner with attached screen, common for tractors that had the #33 Corn picker; ours also had the mud scraper on the front wheels.  R. Musgrave
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmrehn Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2025 at 2:12pm
My Dad bought this tractor used in the mid 60's. I was 7 in 1965. My older brother remembers it had a loader and plow when Dad got it delivered. If it ever had a picker mounted, it was before then. The loader and plow got sold at some time and the WD spread manure, hay work and pulled wagons.It was the first tractor I ever drove with Dad beside me, and the first tractor I got to do work with, raking hay and nearly freezing in one direction and cooking the other way with a heathouser pulling a 2-row stalk cutter.
53WD
kevin LA-CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin LA-CA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2025 at 9:01pm
Any chance you could take some measurements of the spacer?
Height, diameters of inside, outside and step of the ledge.
I am assuming other side is flat.
I might want to make one for my picker.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmrehn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2025 at 5:19pm
53WD
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin LA-CA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2025 at 9:13pm
Jim
Super! Thanks for the great photo documentation.
I think I can turn one up.   Then extend the spindle for my picker.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2025 at 2:18am
 That spacer would have been nice to had, makes for more room for mud to go around instead of getting full of mud up under the engine.
 Dad replaced the 5:00 or 5:50  with 6:00 front tires to hold up better in mud, and made for more mud issues,  and the tires wore out the upper part of the snoot going straight and wore the side shields (that went out to hold the lower part of the front snout) when turning on the ends.
Dad also had put on the next size larger rear tires back in 1962 which made it run to fast in heavy corn so had to slllllip the hand clutch a lot on lodged corn. We had thought about finding a 45 and put the picker on it, but never did.  Bought a NI pull type picker instead and used a tractor with a cab and used the 33 mounted picker to open the fields.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmrehn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2025 at 5:42pm
UP DATE,
Finally got this done,had the radiator out to get some leaks fixed and flushed out. Got it back yesterday. installed today and got to test out the new front end.
Steers great, no shake, it is nice to able to drive in fourth gear without my teeth getting shook loose.
Edited by jmrehn - 11 Jul 2025 at 5:44pm
53WD
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2026 at 11:58pm
Funny I ran into this post, WD I’m going through right now sat high in the front end, wasn’t sure why, just figured it was short rear tires. Disassembled the front end tonight, pulled that spacer off thinking to myself (don’t remember that on that last one) but didn’t give it another thought. Key way is pretty bad on the shaft, but maybe I’ll have to try and weld it up and put it in my picker tractor if that’s what was confirmed they were for. I’ll have to page through the picker parts book.
This page was generated in 0.111 seconds.
