Allis WD Hubs Update |
garden_guy
Joined: 05 Jul 2013 Location: Illinois Points: 1167 |
Topic: Allis WD Hubs UpdatePosted: 04 Aug 2019 at 6:00pm |
So a long overdue update on my WD hubs... As many of you noted to me, on my wheel with about 1/2" play on it, a weird gas cap welded to the hub cap, and with cracked bearing races, that I was in for some surprises... Well, turns out not only were my old inner bearing races cracked, they had also spun in the hub... Like, forever. I went to drop new races in and they fell into place and weeble-wobbled. So I ordered new hubs. ![]() New hubs were pretty nice, other than they missed machining out one of the notches for punching races out... So I drilled that in. ![]() Then a bit of primer and paint on the bare metal stuff. ![]() New races, fresh grease, new bearings, and those locknut deals for my boogered spindle threads. ![]() Everything is together nice and tight now, no slop to be noted and the wheel spins nicely. Got a used hub cap off of another Allis, and will retire (but not throw away) the gas cap welded on hub cap that came with the tractor. ![]() Ran out of steam today though, too hot in the shed to do the other side. Cost me a bit of money, but I feel I will be much happier when I am done here. Thanks for all the advice and assistance -- you guys were right, my hubs were trashed, lol. I should've listened and ordered the parts sooner instead of waiting. |
Joined: 11 Sep 2009 Location: illinois Points: 90812 |
Posted: 04 Aug 2019 at 6:53pm |
Looks GREAT... You got all the GOODIE out of the old hubs , and then some.
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8661 |
Posted: 04 Aug 2019 at 8:10pm |
GG,
Careful, you have done such a good job, the rest of the tractor may be next? I think your going to smile when you start working the tractor again. Really is nice when items are brought back to original factor conditions. Dont forget those damaged threaded spindles can be replaced too. I know your going to try the clamp nuts first. You might want to remove the cap and check them once in a while. If ok your good to go. Thanks for the update and pictures. I have never ordered a new front hub. (yet) Regards, Chris
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5061 |
Posted: 05 Aug 2019 at 6:25am |
When my dad started farming, he had a Farmall F-20. It had grease zerks on the front wheels, and you gave then a shot of grease every so often. He had that F-20 for maybe 10 years, and the front wheels/spindles never gave him a problem.
He replaced that F-20 with one of the last WD's in '53. A wheel bearing went out on it a few years later. I took it over in '57 and a front wheel bearing went out on me. I got to thinking about them not having zerks like the F-20, so every so often I took the screwed on bearing cap off and filled it with gun grease and screwed it back on, which filled the bearings with grease. I had that WD until 1965 and never had a problem with the front wheel bearings again. I have a 720 garden tractor with a loader on it, that I bought maybe 3 years ago, and had a front wheel bearing go out a couple weeks ago, and the other front wheel was a little sloppily. The repair manual stats that you tighten the spindles until all slop is gone, just like all other spindles. But then could not tighten them like that before the nut bottomed out. So I made a special washer for each spindle. Then added a grease zerk to each hub cover. Now we'll see how long they hold up. Dusty
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3252 |
Posted: 05 Aug 2019 at 7:48am |
Good job on the WD . I just did the front wheel bearings/hubs on my D 15 . My replacement hub has a grease fitting also . Thanks
garden_guy
Posted: 05 Aug 2019 at 4:53pm |
So, I did notice that installing the "cup washer" on the inner bearing, you basically had to brass hammer it in with a seal installer, it was super tight... Does this seem correct, everybody? Sugarmaker -- The clamp nut seemed to work good. I managed to get it spun on just right to get the clamp on, and to get a smaller cotter pin in the slot as well, just as extra insurance. But will need to check after running awhile and re-adjust the nut anyway, I figure. Yeah, I think a grease fitting would be great for these things. Taking apart to repack is a chore, no wonder they wear out. I am told that the gas cap got welded on the original hub cap because it "wouldn't hold grease anymore" since it had cut through the cap with the spindle and cotter pin. The next thing to tackle is going to be the wobbly steering on my other
WD (hold the steering wheel straight, front wheels dance, especially in
3rd or 4th gear). May be a good fall/winter project to tear apart... Thanks for the feedback and support, all!
![]() Edited by garden_guy - 05 Aug 2019 at 4:54pm |
Sugarmaker
Posted: 05 Aug 2019 at 9:01pm |
GG,
A successful job on the hubs and bearings! Your good to go on that one! Thanks for the update! Regards, Chris
tom51
Bronze Level Access
Posted: 05 Aug 2019 at 9:45pm |
My dad had the hubs on his WD drilled and tapped for grease fittings inside the flange between the bearings so we could keep the bearings greased worked well for us
garden_guy
Posted: 08 Aug 2019 at 9:35pm |
Finally back out to work on the other side. Bearings were toast, and the race was split in just 1 place on the inner. However, the spindle on the other side is in MUCH, much better condition, which makes me happy. ![]() Didn't feel like using a jack... ![]() My only debate is how close the tip of the spindle should be to the inside of the hub cap (hence where my original one has a welded on cap). Wondering if I may need some shims or spacers to add to the inner bearing spacer (or perhaps double up the big washer on the inside of the hub closest to the pedestal). Anybody have a dimension on that?
Sugarmaker
Posted: 08 Aug 2019 at 9:39pm |
GG,
I dont have a clue as to the clearance. But I havent had any issues with the cap hitting. Glad this side is better!
Regards, Chris |
garden_guy
Posted: 09 Aug 2019 at 9:53am |
Thanks Chris! I figure if I put it all together I can put some colored grease in the cap and screw it on and see if it "touches" the center of the cap. If so, I can take it all apart and maybe put another washer or spacer on the furthest inside of the hub. On the up side, I think I can reuse the actual castle nut and put a new cotter key on this side, so now I have a spare lock nut! Whoo! Also had a couple mismatched lug nuts, so they're on their way from Steiner right now.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8981 |
Posted: 09 Aug 2019 at 12:22pm |
zerk on hubs are ok IF you clean them well before you pump dirt in the bearings....plenty of people who just sick the nozzle in the dirty zerk and start pumping.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4276 |
Posted: 10 Aug 2019 at 7:49am |
Personally not a fan of the zerk on the hub. Much prefer to just 'pack' them. The zerk system gets grease in there but how much actually gets to the rollers? More mess to clean up when they come apart too.
garden_guy
Posted: 24 Aug 2019 at 5:09pm |
Hadn't posted an update in awhile... Anyway, determined that my clearance is bad of the hubcap to the spindle tip -- probably due to excessive wear on the inside of the hub (maybe wore down the casting a bit or the bearing spacer -- hard to tell). So anyway, I was able to hunt down some shims on McMaster-Carr (1.5" ID, 2.125" OD) that are a close match and come in 0.06 and 0.09 thickness. The bearing spacer measured out at around 1.5" ID and 2.0" OD (which leaves clearance for the 2.20" curved seal retaining washer thing). ![]() So I have a buddy turning down the shims for me to 2.0 OD with his lathe so I can use them to take up the slop in the hub assembly now. Probably not the most ideal approach, but I think it should work (this should leave the same dimensions as when it was assembled before with a giant flat washer in the middle instead, but still allow me to properly install the seals).
Sugarmaker
Posted: 24 Aug 2019 at 8:03pm |
GG,
Glad your getting a handle on this hub thing! I believe your going into more detail than I do. Sounds like you have a good approach to fixing the hubs. Regards, Chris
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6124 |
Posted: 25 Aug 2019 at 10:20am |
I'll toss in one more note here. Many times, designers intentionally leave grease fittings off components so that you WILL disassemble and clean, before repacking. Why? Because people frequently do not pay attention to what type of grease is in that gun. Let's say the factory packs a hub with a quality sodium-based wheel bearing grease. Now the homeowner comes by with a grease-gun loaded with a calcium-sulfonate based chassis grease, or waterproof lithium grease... and gives that hub three squirts. Yep, that factory grease is coming out, so it's good, walk away. Now come back six months later, and the bearings are seized, cap blows off, and the nut spins and shears off the cotter pin, spitting the cap off. Why? Saponifcation. It's when two metals of a mixture react, and turn to something kinda like stone. Ever wonder how Loctite works? it's a type of saponification that occurs when oxygen hits the two suspended metals in that red stuff... and when it crystalizes, it expands (like most crystalline structures do). By omitting a grease fitting, it makes sure one of THREE things WILL happen: 1) it'll get ignored, and run on the same original grease for most of it's intended life... 2) it'll get dismantled, cleaned, and repacked with JUST ONE TYPE of grease 3) it'll get drilled and fitted with a zerk fitting, and either be maintained by someone who knows what they're doing, or it'll die soon from saponifcation...
garden_guy
Posted: 25 Aug 2019 at 8:00pm |
Thanks sugarmaker! Unfortunately I don't live where my tractors are, so I have to plan in advance to take a drive to go work on them. I've never really tackled this sort of project on my tractor before, just simple 1-to-1 swaps like water pumps and the 12V conversion on one. I've learned quite a lot and found some more suppliers of parts. I am trying to make do with repairing what I've got, since it has been allowed to wear out for many years now and is worn beyond typical assembly. But I hope when I am done it will last another 50-70 years! Very well said, Dave. Speaking of, you can tell the oil in my old hubs had mixed with dirt and been run out for years without being repacked or inspected, unfortunately.
DaveKamp
Posted: 25 Aug 2019 at 10:01pm |
Hee hee... that happens too. They continued to roll, and at walking speed, that's really all that mattered, right? I had a buddy who told me the story about his dad's old green two-cylinder... bought it new in like... 49... ran it on the farm all the way up 'till '85 or so, then sold it to a neighbor. All those years, Dad told son to 'check and add' oil as necessary... and he says that it never needed much. first thing the neighbor did, was drain the engine oil, rinse the gak out of the pan, and refill it with new oil, and Dad told him "You shouldn'ta done that... you'll ruin that engine'. Well, neighbor knew best... and six weeks later, that tractor's engine seized up and broke a rod. Now, did replacing that old nasty oil cause it, or was it flushing it out, or did it leak out of a seal? I dunno, but it's a strange story, and apparently that tractor is still sitting in the fencerow across from his Dad's farm... {shrug} Now... MY grandpa was not one to be locally known as a wizard of anything other than raising livestock, crops, and cutting trees, but he would NEVER let me touch his grease guns. I suspect he had obtained some unfortunate carnal knowledge of incompatible lubricants at some time, and did NOT care to relive the costly frustrations. I was too young to know much about it when I was helping him as a kid, but I learned later, and was able to associate all the troublesome repairs with that useless information they taught us in High School chemistry. I suspect your old gal will have some more surprises, and accordant tuition to be paid in blood, sweat, and tears, but I'm certain that once you've passed all the classes in steering, internal combustion, gearboxes and clutches, final drives, brakes, tires and wheels, wiring, cooling systems, PTO and lifts, you'll find that real life with tractors to actually be really, really easy, even when the task seemed infathomable before. Some have even noted that working on old tractors is somehow 'theraputic'. For me, it's absolute torture. Why? -- Because, the more I work on old tractors, the more I HATE working on modern cars and trucks. You stand alongside the tractor, and the distributor, carbeurator, water pump, generator, air filter... they're all right there. No bending over, no zillion little plastic clips to break off, no link-straps and engine mounts to remove to lean the engine forward to remove a @#%^ spark plug... Enjoy the simple life of agrarian harmony... and no metric fasteners!!! |
garden_guy
Posted: 26 Aug 2019 at 7:56pm |
That's right. The tractor kept on rolling and the farmer kept on farmin'! Oh man that's a good story. That's kind of like cars that have 200,000+ miles on them and somebody goes and flushes the transmission fluid and then it starts dropping gears... There's something to it. But most of us aren't quite sure what it is. I do find it theraputic, actually. They're fairly simple, albeit it there are anythings above my ability (machine-shop level tasks, and having the proper hoists to move things and jack things, or my inability to weld). But I'm working on it. I'd love a lathe or a mill but that is not in the cards for many years I don't think. Amen to all the pieces being right there, though!
