Allis WD 45: Starting to rebuild
woodman Steve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote woodman Steve Quote  Post ReplyReply Direct Link To This Post Topic: Allis WD 45: Starting to rebuild
    Posted: 19 May 2011 at 10:17am
I am starting to restore the old WD45 that my father and I used to farm with years ago. It has been many years since it has ran. When I opened the sediment bulb valve and tried to start it, the gas ran out of the carb. So, I am rebuilding the carb as the first step. How do I adjust the float so the gas fills to the proper level?
I also have new points, condenser, plugs, wires, etc....
Is cylinder 1 at the flywheel or at the fan side? How do I know which position the rotor points for cylinder 1. etc? My dad had Alzheimer’s and he would often go out and mess with the tractors. We found that he had changed the plug wires around on our other tractors. I assume he did the same to this one and I cannot trust the current positions of the plug wires to be correct. This old 45 is the only one I wanted to keep for myslef, the rest we have sold.
I have not been doing any mechanic work for so many years that I have forgot some of these basic things.
Thanks!
Steve
Sitesstables View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sitesstables Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 10:38am
Hi steve!! Where are you at here in Indiana? Lot of super great info and super great guys on here.. i am in southern Indiana!..
1965 D17 Series IV
Post Options Post Options   Thanks (0) Thanks(0)   Quote woodman Steve Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 11:41am
I am up in the north east corner, about 30 miles North of Fort Wayne.
Gary in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 2:48pm
#1 is by the fan.
I'm not a good carb person for that answer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 7:01pm
Turn the carb upside down and set the float parallel to the gasket surface.
Number 1 in any engine I ever encountered is in the front. Take the plugs out and turn the engine over with a crank or with the front pulley while holding your thumb over number one plug hole. When you feel pressure start to build up you are on the compression stroke of that cylinder. Bring the engine to TDC(noting direction of rotor tavel). When cylinder 1 is at TDC the rotor should point towards the number 1 plug wire. Follow the direction of rotation of the rotor putting the wires in the firing order of the engine.  1-2-4-3
Post Options Post Options   Thanks (0) Thanks(0)   Quote woodman Steve Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2011 at 8:16am
This sounds like the exact info I need.   Thank you!
Steve
paulinkansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulinkansas Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2011 at 9:39am
Carb:
When you put the needle in the seat, give it a light tap with a screwdriver to help it seat properly.
As far as the gap goes, put your float in then hold the carb upside down.  Take a 1/4" drill bit and use that as a gauge.  You want 1/4" between the the float and the carb.
Before you do this.  Clean out everything between the sediment bowl and the viton float needle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote woodman Steve Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 11:37am
I put the rebuild carb and new ignition parts on the tractor this weekend, and it started after cranrking over just a few times.  Now I need to adjust everything to get it running smooth.  I guess after sitting for several years, I felt pretty good that it ran.
Thanks again to everyone for your help.
Steve
