Allis WC engine
Ttague39B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ttague39B Quote  Post ReplyReply Direct Link To This Post Topic: Allis WC engine
    Posted: 6 hours 15 minutes ago at 4:36pm
I recently bought a 1937 allis wc, it has the distillate carb and auxiliary gas tank, so I wanted to check the engine number to see if it was truly a distillate engine, and it started with a "W" like it should, but instead of ending with a "K" or "G" like the book says, it ends with a "HA" and I read on a different forum that it means it was tuned for High-Altitude, and I just wanted to check if this was true, and if there was still a way of proving its a factory distillate engine. Any knowledge on it would be greatly appreciated, Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 5 minutes ago at 8:46pm
You might try checking the compression ratio ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ttague39B Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 28 minutes ago at 9:23pm
I was seeing that myself, any ideas on the best way to do that? I've seen and been told not to trust a compression test of hand cranking, my thought was hook the belt pully up to another tractor.
This page was generated in 0.039 seconds.
