Allis V-Ripper
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Topic: Allis V-Ripper
    Posted: 06 Dec 2010 at 8:09pm
You don't see these very often.  I had to go check my Swinford book just to make sure Allis actually made these.   Someone here should snatch this up as $1350 is cheap compared to similar V-rippers of other (aka green) brands.  Anybody else own and use an Allis V-ripper?  What size tractor would this take???  I'd guess at least a 7060/7080 or 8070??? Mike
http://kansascity.craigslist.org/grd/2085226090.html
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 8:17pm
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 8:30pm
there was one at the Orange Spectacular many years ago behind either a 7580 or a 8550. that is the only one I have seen
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 9:04pm
I wish that was a little closer to me,cause I need one, and it's all the better if it's Allis. I think that would make my 7580 snort a little if ya socked that thing in deep. Darrel
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 9:39pm
Mike I saw that one on Craigslist last weekend but didn't have a tractor that can lift it or pull it. lol
I know you can put it on your 180 and then put two D-17's in front and maybe put the WD45 up there too, if you need some more chains just let me know. lmao
Wade (IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wade (IA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 9:24am
That looks like a nice ripper, I saw it last week as well
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 11:27am
Darn it, Don.  That's what I was going to suggest.  I don't think the One-Eighty could even get the lift arms high enough to hook it up much less lift it off the ground.  LOL.
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 11:51am
That would give a 7080 all it wants.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 5:34pm
A good friend of mine bought an 8550 new, pulled 1 with that.  He was pulling it though bottom ground and had a big rock get stuck between 2 of the shanks, that pulled kind of hard.  Had to loosen up the shank toget the rock out.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 5:54pm
I don't think the 8050 could pull that, my 5 shank can already make her snort.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 5:59pm
I pull a 4 shank Tye Para-till with a 7060 and 7080 both running 210hp. Neither one has trouble with it. The front end gets a little bit light when its hanging on the back even with 1000 on the 7060 and 1400 on the 7080. My uncle pulls a 5 shank Landoll with his 7080 (195hp) and it works it pretty good.
