Allis TL12 u joint |
AC 89
Topic: Allis TL12 u jointPosted: 06 May 2024 at 9:11pm |
Would anyone happen to know what size u joint I would need for the top driveshaft? Figured I'd ask before I take it apart. Thanks
Codger
Posted: 06 May 2024 at 9:16pm |
If you can post measurements and a photo of the joint, I can probably tell you from my books.
That's All Folks!
AC 89
Posted: 06 May 2024 at 9:21pm |
Ok
Edited by AC 89 - 06 May 2024 at 9:27pm |
AC 89
Posted: 06 May 2024 at 9:27pm |
Ok I'll send you a picture tomorrow. My phone is not working. Bad service
AC 89
Posted: 07 May 2024 at 4:01pm |
I've tried posting a picture but my phone isn't letting me
Joined: 11 Sep 2009 Location: illinois Points: 90718 |
Posted: 07 May 2024 at 4:40pm |
picture is not going to help... u-joints are specked by the bearing cap OD and the WIDTH from one edge of the cap to the other.... ... Probalby 20 different sizes or more... get those numbers and you can cross reference.
Posted: 07 May 2024 at 4:48pm |
Edited by steve(ill) - 07 May 2024 at 4:50pm |
AC 89
Posted: 07 May 2024 at 6:01pm |
Ok I'll take it out and do some measuring. Thanks
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 08 May 2024 at 7:22am |
I have a new one in a box can give part # tonight if i can remember
AC 89
Posted: 08 May 2024 at 7:37am |
Sounds good! Thank you
CAL(KS)
Posted: 08 May 2024 at 10:26am |
is this the older tl12 or the later with square front and dump cylinders on loader arms?
AC 89
Posted: 08 May 2024 at 10:34am |
Later with a d17 motor
CAL(KS)
Posted: 08 May 2024 at 11:06am |
they had d17 motor since 57. update came about 1960
joint i have would be for loader in top video. its a 58' i believe and had d17 engine
Edited by CAL(KS) - 08 May 2024 at 11:21am |
AC 89
Posted: 08 May 2024 at 2:10pm |
It looks just like thr one in the second video. It's also orange was that a optional color? Or is it supposed to be yellow? Thanks
CAL(KS)
Posted: 08 May 2024 at 6:06pm |
Ok that is the second style TL-12. Mine is first style. Front and rear universal joint I have is 230-0115. May not be the same for you
Posted: 08 May 2024 at 6:24pm |
this is CALS u-joint... early model
Edited by steve(ill) - 08 May 2024 at 6:39pm |
AC 89
Posted: 08 May 2024 at 6:28pm |
Mine looks just like that with the caps that bolt over the yoke. I haven't gotten the machine yet that's why I asked if anyone would know what u-joint it would need. I'm getting it this weekend.
nowaktj
Joined: 13 Dec 2009 Location: Elk River, MN Points: 735 |
Posted: 27 Jun 2024 at 4:21am |
Hi guys-I have a "newer" TL12 with the D17 engine.
The driveshaft between the engine and transmission has been completely cobbled (even the tire has been removed). What I want to know is whether this driveshaft has a slip joint in it or is it a solid connection? I have included an image from a TL12 with a 6 cylinder engine showing a solid connection. My parts book does not show what this looks like with the 4 cylinder engine. Thanks in advance. ![]() Edited by nowaktj - 27 Jun 2024 at 4:22am |
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Posted: 30 Jun 2024 at 1:15pm |
almost EVERY drive shaft has to have a slip joint to make up for minor difference in component installation, or movement of the trans / axle / engine.. Would be hard to build ANYTHING with a solid length shaft unless everything was perfect dimension.
nowaktj
Posted: 30 Jun 2024 at 1:21pm |
The t l's have a rubber tire in a drum Adjacent to the engine's flywheel. My question is Whether they have a slip joint when it has the four cylinder engine. 6 cylinder do not.
CAL(KS)
Posted: 02 Jul 2024 at 8:03am |
I am curious why they went to this design, on the group 3 Loaders (the redesign in 1960). The earlier group 2 loaders were coupled directly to the converter shaft with a splined collar bolted to the crankshaft and flywheel. It seems counter intuitive to add this driven tire, (which has shown to wear out vs the direct drive) and universal joint shaft which was necessitated by moving the converter away from the engine adding another wear item.
nowaktj
Posted: 03 Jul 2024 at 3:56am |
When someone shifted from forward to reverse in a split second must shock the whole drivetrain system. I wonder if the splined driveshaft wasn't living?
CAL(KS)
Posted: 03 Jul 2024 at 7:30am |
possibly but it goes through a converter so not much shock transferred. the original coupler showed no wear on my machine.
nowaktj
Posted: 30 Jul 2024 at 10:21am |
Found a manual at the Orange Spectacular and it shows a tube of a driveshaft taking up the extra distance when the 4 cyl D17 engine is installed.
![]() Edited by nowaktj - 30 Jul 2024 at 10:32am |
