Allis t handle pops out of gear
timmiso View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote timmiso Quote  Post ReplyReply Direct Link To This Post Topic: Allis t handle pops out of gear
    Posted: 1 hour 59 minutes ago at 2:18pm
Got a 7060 with t handle shifter that pops out of gear in reverse. When I’m shifting it if I take it in and out of reverse a few times you can tell when it catches and then it is fine. It’s almost as if the detent balls are not falling in to the groove on the shift rail. Is there an easy way to fix this and make it work 100% of the time right off the bat. I’ve tried adjusting the cable linkages and it doesn’t seem to make a difference. Once it’s in good (you can feel it if you try to pull it out) it works great.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 30 minutes ago at 2:47pm
Following this! My 7045 does this too, sounds identical. Sure can make a guy mad. Especially if you’re almost stuck and trying to work your way out.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 29 minutes ago at 3:48pm
My 7060 and 7020 act like that also. It feels squishy going into gear. Feels like cable ends are not secured good enough or worn out cable. Plan to get them in the shop soon to try to figure it out. I know it shifts better if I take my time rotating t handle and getting into center of that detent before trying to get into any gear.
Leon B Mo
