Allis Power Unit |
Post Reply |
JCSinPITTS,PA
Silver Level Joined: 14 Sep 2009 Points: 223 |
Posted: 17 Sep 2020 at 7:59am |
I have an AC power unit that was in storage I placed on EBAY and the buyer decided it was too far away for pickup. I am now trying to get it running so it will be worth more $$. It has a starter and I assume it would be POS to ground? is that correct? I want to spin it over until I get oil pressure before attempting to start.
DiyDave
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50493 |
If its a U power unit, it may be 6V pos ground. Don't worry too much, though, a couple of minutes of 12V might do it some good...
Fred in Pa
Orange Level Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9096 |
With just a starter ,Pos or neg will work .U have a mag and no charging system .Spin oil filer off ,when u get oil out tube you will be OK .Put filter back and go from there . Pulling the spark plugs out will help spinning it until u get oil. U can also check if u have compression be for starting ,if carb and mag work.
Edited by Fred in Pa - 18 Sep 2020 at 5:18am |
nonetheless ,still dead. If all else fails ,Read all that is PRINTED. Just because you do not have the tools for job , it dose not make it a bad design. |
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8167 |
JCS,
I have a friend that is interested in the engine. Please PM me with your contact information. Regards, Chris
Sugarmaker
JCS,
Sent you a p.m. Regards, Chris
JCSinPITTS,PA
i will call ur friend
had to remove starter to free up little gear on the end and used a jump box with NEG to the ground to spin over. Got oil coming outta the little tube now!
JCSinPITTS,PA
I have received several questions about this. I don't know what its worth since it doesn't run. I got oil coming up thru the tube but haven't got magento sent out for repair yet. the starter works after i oiled the little gear on the end of the starter shaft and tapped it back and forth. I placed it on eBay at $200 and was hoping it would go to $500-600 but it didn't. SO make me an offer.
just remember its located in Western PA and its HEAVY!
JCSinPITTS,PA
search COMPLETED ITEMS at EBAY for "Allis Chalmers Model U Power Unit" for more info
JCSinPITTS,PA
Cost was $250.00 to get magneto repaired so its NOT going with power unit. Guy that wanted last year ran into some $$ problems so Its for sale again. never installed magneto since is cold and will wait until spring to try to start.
Post Reply | |
