Allis planter help
poorboys151 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote poorboys151 Quote  Post ReplyReply Direct Link To This Post Topic: Allis planter help
    Posted: 03 Feb 2017 at 7:13pm
Would like to know what sprocket and plate combinations would plant 120-150000 soybeans per acre on 18" rows with 50/60 series units thanks for any help
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2017 at 1:57am
I plant a bag (approx. +/-) per acre from 50 lbs bags. dunno how many ina bag, on 30 in rows. this is a bit thicker than most do. but has always given me great stands.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2017 at 2:02am
i'm thinking that your needs are about the same as drilling populations. takes more seeds than 30 inch populations, but will only yield as much as 30 inch. most all farmers I've talked to in NE and IA used to drill the beans, and most have gone back to 30 in rows as the yields are the same or better on 30 inch than drilled and using less seed doing it. only thing I can see with drilled or narrower rows is they do combine better cutting at an angle.
