Allis Mdl G |
Brad W Wi
Joined: 15 Sep 2009 Location: Winter, Wisc Points: 39 |
Topic: Allis Mdl GPosted: 11 Jan 2017 at 3:54pm |
Wondering if anyone out there knows if A/C made a snow blade for
the mdl G? I've been using one on my G the last 2 winters. It sure looks factory made and the color is right. No data plate or any kind of ID on it that I could find.It's a flat blade with holes and bolts for putting some pitch on it. It sits out front of the tractor. I made up some tire chains for it and I'm happy with the job it does. It does have some limitations though. Spun off 2 axels last winter, but even I learned something. |
Brad W Wi
Gerald J.
Posted: 11 Jan 2017 at 5:23pm |
The G implement book I have on line in a couple pieces doesn't show a blade, but parts of several implements including the hand lift used by several would carry a blade with mostly Allis G parts. Then these manual scans could be old enough and a blade a newer product.
http://www.geraldj.networkiowa.com/Trees/Model%20G%20Implement%20Setup%20(TM-3)%20PART%201.pdf http://www.geraldj.networkiowa.com/Trees/Model%20G%20Implement%20Setup%20(TM-3)%20PART%202.pdf Gerald J. |
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4901 |
Posted: 11 Jan 2017 at 7:58pm |
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
Gerald J.
Posted: 11 Jan 2017 at 9:02pm |
Looks like a blade mounted on a cultivator frame.
Gerald J. |
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8459 |
Posted: 11 Jan 2017 at 9:06pm |
I thought about doing that with my G. Just making a blade to mount on the cultivator frame.
littlemarv
Joined: 10 Jun 2013 Location: Wisconsin Points: 1834 |
Posted: 11 Jan 2017 at 9:42pm |
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
Ross D.
Joined: 02 Sep 2013 Location: Erin, Ont. Points: 339 |
Posted: 12 Jan 2017 at 8:40am |
Good morning. Check this out. As with most things, it only takes time and money. Ross.
CrestonM
Posted: 12 Jan 2017 at 10:01am |
Whew! That looks hard to steer, with all that weight!
Eldon (WA)
Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Posted: 12 Jan 2017 at 10:20am |
ALLIS EXPRESS!
This year: |
